Another guitar kit build
Re: Another guitar kit build
Postby Martin Walker » Tue Jun 02, 2020 2:40 am
I truly envy your seemingly endless reserves of energy Drew ;)
Postby blinddrew » Tue Jun 02, 2020 10:35 am
I suspect most of that energy will be expended on sanding the back and sides back to wood again.
This has been a very frustrating experience so far. A series of 'close but no banana' situations.
I think it's called 'learning' or something like that...
Postby ManFromGlass » Tue Jun 02, 2020 1:04 pm
I built a bathroom countertop from 2” slabs of pine. One joint was end grain to end grain and it didn’t glue up properly. I spent a long time cleaning the gap and trying to fill it with wood epoxy but only made the tiny line worse.
The only way to fix it is to make the line wider and refill it which defeats the purpose of glueing those two pieces together. For now I’ve stepped back and installed it. I consider it the rehearsal. When I have the juice for it I will redo it and call it the performance.
But after almost a year without the bathroom has a working sink so I managed to accomplish something even if it wasn’t how I thought it would go in my mind. So I commiserate with you Drew. I must admit, working with my hands gives great pleasure, as opposed to many hours in front of a computer screen.
Postby blinddrew » Thu Jun 04, 2020 5:29 pm
The back was not saveable
The sides may yet be.
I'll have another try at a burst otherwise we'll be going solid.
Postby blinddrew » Sun Jun 21, 2020 2:43 pm
Well, about three weeks on I'm pretty much back to where I was.
Restained and sides redone:
So, time to try that burst again.
Step 1:
Step 2:
Step 3:
Detail of the burst:
It's not the effect I was going for but actually I like it, it's a bit rough/vintage, so it's staying.
The front is largely going to plan:
So now that the colours are fixed behind a couple of dry layers it's largely a case of building up the finish and sanding through the grades.
Unless I balls something else up...
