Speaker mount 1/4” = 6mm?
Re: Speaker mount 1/4” = 6mm?
Postby wireman » Thu May 14, 2020 7:14 pm
I'm responding to lockdown by purchasing more tools that I won't use very often. The latest is a tap and die set and while researching threads I found this...
https://www.teesing.com/files/en/brochures/Teesing-type-of-thread.pdf
Probably more than most people need to know.
My next step is to decide which new drill sizes I should buy (beyond 0.5mm steps).
wireman
Postby ef37a » Thu May 14, 2020 7:36 pm
While you are at it get a can of proper thread cutting lubricant. RS Comps used to do it and it was vastly superior to 3in1 or WD-40 in that it seemed to make the tap sharper!
If you are really into fancy, one-in-a-years use tools get some Cobalt (gunsmiths) drills.
Postby Sam Spoons » Thu May 14, 2020 7:45 pm
If you mean is a ¼" nut/bolt interchangeable with a 6mm the answer is no, not with any reliability but there are 4 comonnly used ¼" threads, BSF, BSW, UNF and UNC and two metric 6 x 1mm and 6 x .75mm.
I've downloaded that doc BTW, very interesting and useful.
Postby Folderol » Thu May 14, 2020 7:51 pm
Interesting, but I don't see BA thread mentioned :(
Postby ef37a » Thu May 14, 2020 7:57 pm
Folderol wrote:Interesting, but I don't see BA thread mentioned :(
Ooo! I was once told by an old tool maker that the BA was the strongest thread there is but I guess metric fine has overtaken that accolade?
Always weird I thought that electronic kit in UK used mainly 4 and 6 BA whereas on the continent we thought they used 5 and 3BA because the spinners fitted!
Postby Eddy Deegan » Thu May 14, 2020 8:56 pm
ef37a wrote:While you are at it get a can of proper thread cutting lubricant.
+1 to this. There are different thread cutting lubricants but one that's a little too popular with some folks is a bright red colour and comes packaged in people.
Some of my works.
Postby Sam Spoons » Thu May 14, 2020 9:01 pm
Slipped my mind :blush: TBF the largest BA thread (0BA) is the 6 x 1mm......
Wiki article here :- https://en.wikipedia.org/wiki/British_A ... ew_threads
Postby Sam Spoons » Thu May 14, 2020 9:05 pm
Happy to announce that my workshop (and lathe turning) escapades have, so far, not resulted in the liberation of any biological lubricant. I don't foresee the situation lasting long but I live in hope :D
Postby wireman » Thu May 14, 2020 9:25 pm
I have taken the hint and ordered some paste, given how many HSS drills I have overheated in the past this should be a good thing.
As for Health and Safety, I'm worried more by soldering irons.
wireman
Postby zenguitar » Thu May 14, 2020 9:32 pm
wireman wrote:As for Health and Safety, I'm worried more by soldering irons.
Not my first choice to tap a thread.
Yogi Berra
