Blank Studio Canvas - Where do I start
Postby Scouser » Sat Jun 27, 2020 11:31 am
Hi Folks,
I finally have a room in the house which I can devote to recording and shooting video.
Problem is, where do I start ?
None of the rooms in my house have decent acoustics, low ceilings, boxy sounding.
I can upload photos if that is necessary. I don't even know the best place to locate static items like my desk etc, I know that sounds crazy, but it's the truth.
Obviously I will be looking to do my recordings and filming here. As for the type of recordings, acoustic guitar and vocals mainly.
So if anyone can get me started, would be very grateful.
Scouser
Re: Blank Studio Canvas - Where do I start
Postby Sam Spoons » Sat Jun 27, 2020 11:42 am
Just a few random thoughts :-
A bigger room will sound better than a smaller one (and give you more room to install acoustic treatment).
A room with a party wall is likely to have more problems with noise from the neighbours and your noise disturbing them.
A room at the front of the house is more likely to have issues with street noise.
Video want's a decent looking background (though, depending on the nature of the video footage, that may be your studio desk or WHY).
There are loads of threads on here and articles in the magazine about setting up a project studio so it's well worth doing some googling/reading
When you have decided which room post some details and, maybe, a plan and we can advise where to place different elements like the mixing desk/computer screens and acoustic treatment.
Postby Hugh Robjohns » Sat Jun 27, 2020 12:21 pm
Good outlines from Sam there.
I'd add that for audio purposes, a rectangular room is better than a square one, and a cube room is worst of all (the typical 8 x 8 x 8 box room is a nightmare!
In a rectangular room, it's best to place your desk and monitors on one of the short walls, firing down the length of the room.
Try and avoid placing the monitors/desk where the side reflection (mirror) points are windows!
At the end of the day, the room has to be practical for your intended purposes, so some compromises are inevitable....
Postby MOF » Sat Jun 27, 2020 2:13 pm
Is the filming of you in your studio environment or are you using a green/blue screen?
If the latter then, especially with green screen, you need to be able to keep some distance between you and the screen to avoid green light spilling on you, making it harder to key out the screen when electronically replacing it with a new background. So you need to be filming along the longest room dimension.
MOF
Postby Scouser » Sat Jun 27, 2020 4:18 pm
Thanks so far for the replies.
Is there a way I can upload a sketch/diagram/photo of the room so I can be more appropriately advised ?
Scouser
Postby zenguitar » Sat Jun 27, 2020 4:22 pm
We don't host images here, but you can upload to an online hosting service like Flikr or Imagr and use the links they provide to embed the image here.
Yogi Berra
Postby Scouser » Sat Jun 27, 2020 4:31 pm
Thanks Andy, I will look into that and post a link here
Scouser
Postby Scouser » Mon Jun 29, 2020 2:33 pm
Hi Folks,
Thanks for your patience. I have now uploaded a plan of proposed studio, dimensions here:
https://drive.google.com/file/d/1ZydUIy ... sp=sharing
Hugh, You answered the first question I was going to ask, placement of the desk. I have taken on board what you said and am hoping it would be ok, to place desk at chimney breast end. As I would like to shoot down away from chimney, would that work ok, or will window be a problem ?
My second question: On page 2 of my document above, is a diagram of a rockwool panel I made. I have two of these and it was my hope to possibly cut each one into 3 new panels and re cover ( with suitable fabric ) for hanging on the walls. Would something like that work or maybe fewer bigger panels, or would Rockwool be the wrong materials for this purpose ?
Scouser
Postby Hugh Robjohns » Tue Jun 30, 2020 1:24 pm
Scouser wrote:...am hoping it would be ok, to place desk at chimney breast end. As I would like to shoot down away from chimney, would that work ok, or will window be a problem ?
Windows are always a problem! Without knowing how big your desk is it's hard to be precise, but I'm guessing that window will probably end up at or slightly in front of the mirror point. So it would be helpful from a stereo imaging point of view to have a broadband absorbed over it if you can bare to be without the daylight -- or maybe a removable panel that you only put up when you're doing your most critical listening.
...it was my hope to possibly cut each one into 3 new panels and re cover ( with suitable fabric ) for hanging on the walls. Would something like that work or maybe fewer bigger panels, or would Rockwool be the wrong materials for this purpose ?
Rockwool is fine. The depth of the panels will determine the low end of the frequency range over which they are effective, and spacing them away from the wall will extend that lower. I generally try and space the panel about as far as it's own depth where practical. So a two-inch panel two inches from the wall...
Obviously you need to place absorber panels at the side mirror points as a first step. One of your existing panels might make a good ceiling cloud if it can be suspended easily. Add other panels as needed to control the room sound, being careful to maintain an even frequency balance.
It's very easy to over-damp the high and mic frequencies while the LF still bounces around giving you a very uneven bass response in the room. Typically you want something like 25-30% of the walls covered with acoustic treatment as a rough target.
But I'd start with the mirror points (side walls and ceiling cloud), and assess from there. You may then want to put absorbers on the wall behind the speakers, and possibly then on the back wall (if your photography requirements will allow that), and then around the room as necessary to give a good even sound.
And if you're planning on placing your monitor speakers in those alcoves either side of the chimney breast, be aware of the likelihood of bass boost due to the proximity of boundaries. So you might need to experiment with the speaker's low-end EQ options to get things balanced.
Postby Philbo King » Wed Jul 01, 2020 3:06 pm
One thing I found about windows:
The reflections they cause can be mostly mitigated by covering the opposite wall (across from the window) with absorbers, covering the wall with at least 60% of the area of the window.
I have a huge window (136"W x 79"H) on one of my side walls, and a sliding glass double door, both on the same side wall.
I placed absorbers using a series of measurements in REW over the course of 3 days, covering each wall in turn to determine what peaks/valleys/reverb freqs could be attributed to each wall. I was surprised how much covering the side wall across from the windows improved both reverb decay frequency flatness and overall freq response. This is only killing one reflection mode, but that mode seemed to be a predominant source of problems in the acoustics of this room. The windows have no curtains or shades, so basically they are just glass surfaces.
Hopefully you'll find this tip helpful.
Philbo King
Postby Sam Spoons » Wed Jul 01, 2020 4:48 pm
The main issue with that, as far as I can see, would be to unbalance the stereo image. If they are behind the mirror points/mixing position it may not be a significant problem but in front of the mixing seat would be another matter.
