Blank Studio Canvas - Where do I start
Re: Blank Studio Canvas - Where do I start
Postby Sam Spoons » Fri Jul 10, 2020 9:32 pm
I used Cara fabric on my panels and the results look far more professional than my modest DIY skills would suggest. It ain't cheap but it is easy to get a decent result.
Postby blinddrew » Fri Jul 10, 2020 10:04 pm
+1 for that.
Not sure where you're based, but someone in London was selling a stack of home-made treatment panels in the small ads earlier this week >>>>
Postby Scouser » Sun Aug 09, 2020 1:49 pm
Ok, so as mentioned I am going to make 3 panels from the 2 existing ones.
This will mean 3 panels 80cm wide, as I mentioned in the earlier post it was my hope to fire down the room from the chimney breast end that has now changed, it will be the other way around.
I just wanted some advice on where the panels would be put to best use, ie I have 4 possible spaces and 3 panels, here is diagram of room https://drive.google.com/file/d/1ZydUIy ... R-PpS/view ( hopefully that link works if not it can be found on page 1 of this post. I am aiming for the 25/30% coverage that Hugh suggested.
Scouser
Postby Hugh Robjohns » Sun Aug 09, 2020 2:30 pm
You've really got to do the left and right mirror points. So the debate is just what to do with the third panel. The back wall/ chimney breast, the front wall behind the speakers, or as a ceiling cloud? I'd try all three and see which works best.
