New (imperfect) Garden Studio Build
Re: New (imperfect) Garden Studio Build
Postby Blott » Mon Oct 19, 2020 1:42 am
blinddrew wrote:Fingers crossed.
One thing that I've discovered is the value of just having a dedicated space to create. Acoustically treated/sound-proofed or not.
Oh yes I absolutely agree, just having your own dedicated 'zone' to create & record music is great regardless. :)
I can't tell 100% yet how effective it's going to be, as I'm still waiting for the 2nd fitting of the electrics which has been delayed (happens tomorrow), then I'll be painting the internals before moving furniture & gear in.
At the moment it's empty and MUCH more reflective than my prior studio build was in the same state (largely because of the laminated flooring and the two windows), both of which bounce sound and were not present in my previous garden studio which had just one very small window and thick underlay & carpet flooring.
However I wanted some 'life' to the sound of the room this time and I've a carpet rug for the floor and a sofa etc to go in which (combined with the window plugs) I'm hoping will tame those reflections enough for it not to matter.
In the worst case scenario I'll remove the laminate flooring and carpet the room as I did in my previous studio build.
Ultimately I just hope it'll be 'good enough' (fingers crossed). :)
Blott
http://soundcloud.com/blottuk
http://blottuk.bandcamp.com
Postby Blott » Tue Oct 27, 2020 11:47 am
The good news is the build is finished...hoorah! :)
The bad news is the laminate flooring just isn't working for me, it's too reflective even with the rug laying on it and a sofa inside. I know I could try and control this more with room treatments, but I'm not sure I have the time and patience required to do that properly, so I'm leaning towards carpeting the room instead.
Also I don't think my two tone choice of colours is working either, so I'm probably going to have to repaint the interior.
The tried and tested cave like asphalt grey is currently favourite! :)
For anyone interested in how the (empty) room currently looks I'll be adding further images to the google photo album soon (link below). :)
https://photos.app.goo.gl/aFBtdoCJAe11HzSk8
Blott
Postby Hugh Robjohns » Tue Oct 27, 2020 12:29 pm
Blott wrote:The bad news is the laminate flooring just isn't working for me, it's too reflective even with the rug laying on it and a sofa inside.
Do you have acoustic treatment up yet? If not, I wouldn't rush to rip it up!
With effective broadband absorbers on the mirror points, bass traps in the corner, and a cloud overhead a laminated floor isn't normally a problem -- and in most cases it's actually very useful and practical!
A carpeted floor is no substitute for properly located and effective acoustic treatment. Not even close...
Postby Blott » Wed Oct 28, 2020 12:15 am
Thanks Hugh,
The laminate floor is still intact as present! :)
My problem with the room treatment is the cost...
The build of the studio itself has already gone over budget by around £1000. :(
Gik Acoustic room kits start from £600 and the cheapest room kit with clouds sets you back nearly £800!!!
Funds are very tight now, in fact to quote Sir Edmund Blackadder "I'm as poor as a church mouse, that's just had an enormous tax bill on the very day his wife ran off with another mouse, taking all the cheese"! :)
Obviously I'd have the best of everything if money was no object, but sadly the reality is I can't afford to do too much more right now - I've £400, could probably scramble to £500 but that's my lot!
The studio isn't big. It's only 15ft long, 9ft wide with a 7' ceiling and I worry that the amount of treatments necessary to control this level of reflection may just make a small studio space feel even smaller.
Of course I'm not arguing that a carpeted floor is a substitute for a properly treated room (I know it isn't), but it was effective in helping deaden my prior home studio and I'm thinking it may be a better compromise solution - at least in the short term.
I can have the floor carpeted with a decent 12mm underlay and thick pile carpet for £330.
If you're saying I could achieve better results with acoustic treatments for around the same cost then I'd definitely do it.
Blott
Postby Sam Spoons » Wed Oct 28, 2020 12:28 am
I built 10 acoustic panels using Cara fabric, 2 x 1 PAR timber and 50mm thick Rockwool RW3 for around £300 to go in my 4 x 4 x 1.9m room.
Build you own using the cheapest timber and weed block fabricant, if you use RW3 you can cover them over the top with something nice like Cara fabric later when funds allow and you won't have compromised the effectiveness of the panels.
PM if you want detail on how I made mine...
Postby blinddrew » Wed Oct 28, 2020 12:37 am
I was going to ask how your DIY was?
Postby Sam Spoons » Wed Oct 28, 2020 12:46 am
Judging by the earlier posts I'd say Blott's DIY skills are adequate at worst :D
Postby blinddrew » Wed Oct 28, 2020 12:49 am
Oh the build is nice alright! I just wasn't sure who was doing the building... ;)
Postby James Perrett » Wed Oct 28, 2020 12:59 am
Your budget is just about right for acoustic treatment if you are prepared to DIY. A couple of bales of Rockwool, some wood to make the frames and Cara fabric to cover them will probably come in under budget (or at least they did when I last treated a similar size room a couple of years ago).
Postby Luke W » Wed Oct 28, 2020 10:43 am
I also built the majority of my panels for around that number, it’s certainly possible. With everything else you’ve done then I think it’s worth it at this stage as well, it’ll be a great overall result.
As already mentioned a reflective floor with your walls and ceiling taking care of the absorption is generally a good thing, so if it’s a choice between the carpet or some DIY panels, I’d be going for the latter every time.
Luke W
Postby Hugh Robjohns » Wed Oct 28, 2020 10:52 am
Blott wrote:My problem with the room treatment is the cost...
Everyone always says that... But it's not a 'nice extra' -- it's what makes the room usable as a studio. Otherwise all you've done is build a small spare bedroom down the garden with all the same compromises and limitations.
For anyone starting out down this road, acoustic treatment really should be included in the initial project build costs planning, just as much as the windows or the flooring or the mains wiring, or the ventilation!
DIY acoustic panels would save a lot of money over commercial products.
Postby Blott » Wed Oct 28, 2020 1:20 pm
Thank you for the responses.
I've decided to go with the acoustic treatments and will let you know how I get on.
Will definitely do a before and after video too! :)
Blott
Postby Luke W » Wed Oct 28, 2020 1:30 pm
Blott wrote:Thank you for the responses.
Looking forward to seeing how you get on :thumbup:
Luke W
Postby Sam Spoons » Wed Oct 28, 2020 3:19 pm
The construction method I used was as simple as it could possibly be but they have proved very satisfactory, at the risk of boring the whole forum I'd be happy to post details....
Postby Blott » Wed Oct 28, 2020 5:10 pm
Thanks everyone.
My woodwork and carpentry skills leave a lot to be desired, so although I know it's a simple DIY task for most to make them it won't be that simple for me, so unless anyone can give me a good reason not to I'm probably going to purchase a couple of sets of these...
https://www.ebay.co.uk/itm/6x-Mafia-Panels-Acoustic-Sound-Proofing-Panels-Complete-Studio-Set-160-00/283962137960?hash=item421d765d68:g:SYwAAOSwmlZfIL27
Which at £320 fits the budget perfectly.
In the mean time I will repaint the studio to be 100% asphalt grey. At the moment it's two tone grey with asphalt and a lighter grey and the light grey is just too...well...light! :)
For anyone interested a photo of the studio as it looks right now with only a sofa inside can be viewed here...
https://www.dropbox.com/s/h5juclgr6wn4bsy/Studio%20Interior%202%20tone.jpg?dl=0
I'll upload more photos to the google folder when I get a chance in the next day or two. :)
Blott
