sprinkler issues
Page 1 of 1
sprinkler issues
PostPosted: Tue Sep 22, 2020 9:36 am
by paleface
hello people
in the flats where i live the council has fitted a sprinkler system
and ive been trying to find ways to protect stuff if its triggered
potentially
if im playing guitar and it goes off
whats the worse that could happen (shock ? death )
and does anyone sell cheap waterproof guitar and mic leads?
Re: sprinkler issues
PostPosted: Tue Sep 22, 2020 9:57 am
by Sam Spoons
Sprinkler systems are usually triggered by a heat sensitive device in each sprinkler head so will only trigger if there is a fire in the room. A newly installed system should be pretty reliable WRT accidental triggering so, unless you are descended from Nero :D I don't think you need to be worried for a few years at least.
WRT waterproof cables, I doubt they exist, guitar and mic cables don't carry any high voltages in normal use and, assuming your other gear (guitar amp, computer interface etc.) is in good order and RCCD protected the RCCD should trip as soon as enough water enters the equipment to allow mains voltages to reach any earthed components*.
* I'm in the UK and don't know enough about US/European mains supplies to comment.
PostPosted: Tue Sep 22, 2020 10:00 am
by Hugh Robjohns
If the mains consumer unit in your premises is fitted with RCDs you have nothing to worry about. If its not (and still using legacy fuses) then using an RCD adapter plug on the mains distribution for your amp would be a very wise precaution.
PostPosted: Tue Sep 22, 2020 10:26 am
by shufflebeat
Thank goodness it's not an aged related medical thread.
PostPosted: Tue Sep 22, 2020 11:15 am
by Sam Spoons
Or possibly worse :blush:
PostPosted: Tue Sep 22, 2020 5:41 pm
by paleface
i think theres rcd on mains
the fuse box was updated a couple of year back
im using an apc on my main comp and running guitar pedal(variax power supply )
through it .
theres 24 or 26 floors in the building where i live
so liklleyhood of leak (or sprinkler being triggered in a flat above is possible)
is the apc good enough as it is ?
it protects from power surges
or should i use an rdc plu as well?
PostPosted: Tue Sep 22, 2020 5:49 pm
by Hugh Robjohns
paleface wrote:lm using an apc on my main comp...
If you mean an apc UPS, then the fuse box RCDs wont protect you. You need an RCD on each of the outputs of the UPS -- and few UPS devices have protected outputs.
Highly unlikely!
Or should i use an rdc plu as well?
I would!
PostPosted: Fri Sep 25, 2020 12:33 pm
by paleface
thanks for the knowledge people
would something like this,
https://www.ebay.co.uk/p/1905274249?iid=203094695981
be good enough ?
its costing me an arm and several legs as it is
PostPosted: Fri Sep 25, 2020 5:03 pm
by James Perrett
I've used something very similar for years with garden power tools. I'd say that's exactly the sort of thing you need.
PostPosted: Fri Sep 25, 2020 5:52 pm
by BJG145
shufflebeat wrote:Thank goodness it's not an aged related medical thread.
You've ruined this thread for me now.
