Alternative to Boss ACA 240 PSU.
Postby shufflebeat » Mon Oct 12, 2020 4:52 pm
I have just resurrected an old Roland PC-200 mkii keyboard and donated to #3 for his midi duties.
If memory serves I used it a few times with batteries but would now rather have a psu attached. It's expecting the unreg'd Boss ACA 240 but research suggests that might be a bit of a pain to locate.
Is there a better, more available option?
(It's got keys - I'm way out of my comfort zone).
shufflebeat
Re: Alternative to Boss ACA 240 PSU.
Postby Mike Stranks » Mon Oct 12, 2020 7:50 pm
I may be missing something, but I just put Boss ACA 240 into a well-know search engine and got loads of 'replacement fors' at around the £10 mark...
... Jus' sayin'
Postby shufflebeat » Mon Oct 12, 2020 8:22 pm
Yeah, I've probably gone round this the long way, I really haven't quite worked out the 20th century yet.
I got as far as "unregulated 9v is not the same as 9v regulated" and thought I should seek advice. Bleedin' obvious really.
Erm, cheers for your extensive and indefatigable search, Mike. I'll try to learn from your obvious superpower.
shufflebeat
Postby Folderol » Mon Oct 12, 2020 8:35 pm
shufflebeat wrote:Yeah, I've probably gone round this the long way, I really haven't quite worked out the 20th century yet.
Unregulated is usually just a transformer and cap arrangement. Simple, a bit heavy, and sometimes lets hum though. The voltage can jump about a bit depending on load, but is otherwise clean and (usually) reliable.
Regulated is usually, switch mode, lightweight, and very stable, but can generate some HF noise.
Postby Sam Spoons » Mon Oct 12, 2020 9:24 pm
This article might help https://mojostompboxes.com/blogs/archive/correctly-powering-your-old-boss-pedal-aca-vs-psa-simplified but as long as the voltage is right* I would just use whatever I had to hand. In fact there's a possibility I'll have something suitable in my large box of redundant PSUs, PM if you want me to have a look.
* FWIW the article suggests the ACA 240 puts out an unregulated 12V and the voltage regulation is in the pedal so any 12VDC supply should work.
Postby shufflebeat » Tue Oct 13, 2020 10:24 am
Sam Spoons wrote:This article might help https://mojostompboxes.com/blogs/archive/correctly-powering-your-old-boss-pedal-aca-vs-psa-simplified but as long as the voltage is right* I would just use whatever I had to hand.
Very helpful, I had seen a very similar article without the helpful suggestions
I have just such a box and once I've ferreted through that I may just be in touch, thanks muchly.
There is hope.
shufflebeat
Postby shufflebeat » Tue Oct 13, 2020 1:25 pm
I think I understand this stuff a little bit but when I dig into the vagueries of the behaviour of forces I realise it's quite a lot like sound and I'm much more a musician than a technician so my general approach of "poke it til it sounds good" could get me in quite a lot of trouble.
Cheers for the input.
shufflebeat
