Looking for help to fix power supply
I have a Creative Soundworks DTT3500 surround system that has been used as the main speakers for my last couple of PCs (I use monitors via an interface for serious audio use).
These have developed a hum which I have been investigating as I have a few spare days at the moment.
I think the issue is the 15V 4A power supply that provides the DC input to the system.
The output is not grounded but I think there must be a serious problem with the supply causing the hum. The following waveforms come from an oscilloscope connected to the output with a 20Ω and then a 10Ω resistor load.
Note that the vertical scale is just wrong, the blue arrow is the zero point, the Rigol Ultrascope software is often inconsistent with the scope on the vertical scale. I think the horizonal is correct althought I don't understand the 100Hz waveform. The average voltage is around 12V.
On opening the box this looks like a bridge rectifier circuit, although with capacitors in parallel with the diodes which I was not expecting and have never heard of.
I'm strugging to work out what is wrong from that waveform, I could understand a faulty diode giving you nothing on one half cycle of the mains but the waveform falls before it gets to the point where it looks like we have capacitor decay.
Further images below of the supply internals:
Should I get on the right track I can buy the components and attempt a fix. I was hoping the waveform would reveal the issue and I would not have to dismantle parts of the circuit to find out what was wrong.
From what I can see we have:
Diodes: 6A2BL (this exact model does not seem to exist)
Parallel caps: 104nF (assuming from the 104 written on them)
Smoothing cap: 6800μF 25V 105°C
Fuse and a resistor (1kΩ?)
I tried to join an electronics forum to post this but unfortunately I don't get the verification email, but if anyone can suggest an alternative forum for this question that would be helpful if needed. I'm hoping someone here can help.
