Folderol (from another thread) wrote:I'm wondering what type of lights you're fitting to the dangly bits and how you're attaching them. I always stick some wood between the joists behind the plasterboard with something like a 30mm hole for the danglys. That way you have a secure mounting whatever you use, and no worries about maybe changing the fitting later.
That'll all be taken care of by the sparky. The dangly bits are only there to facilitate installation of the lights after the ceiling boards are up. The fittings will be lightweight shallow circular LED lights set flush into the double-layered ceiling plasterboard itself.
These are all positioned mid-way between the ceiling timbers, have no rigid attachment to any of the timberwork and will therefore be at one with the ceiling on the resilient bars.
