Suggestions for Studio Air-Con and Acoustic doors/ Windows
Hi all,
I posted a couple of months ago about a studio build project in the grounds of a youth centre. After showing you photos of the garage I'd been offered to use, the general consensus was that it would be better to knock the garage down and start again.
I've been looking into the possibility of a straw bale build, but after doing some research, it is a much more costly and time consuming process than I'd originally thought. So I'm reverting to Plan B, and will be replacing the garage with a timber frame building.
The design will incorporate a floating floor / walls and roof system, probably similar to one supplied by a company called the Soundproofing Store:
https://www.soundproofingstore.co.uk/st ... ndproofing
I want to include air-conditioning, one acoustic window, and 2 heavy duty doors to create a sound-lock, and I wondered if anybody has recommendations for these items? I've got a total budget of around £15k, £5k for the timber frame, £5k for the soundproofing, and £5k for the air-con, doors and window, plus acoustic treatment.
