Could anyone suggest a good power distribution box for my studio please. I'm trying to avoid contorting myself to turn the mains plugs on, and I have a preamp and keyboard that don't have their own on-off switch, and can only be turned on via the mains, which is frustrating. I've found this:
https://www.pennelcomonline.com/en/gb/P ... TMQAvD_BwE
which seems ideal as it has a switch per plug. There are also various Furman / Samson etc makes that are more commonly seen in the music shops. I don't really know the difference, only that the Penn Elcom looks the business.
Any thoughts very welcome!
Many thanks,
Alex
Power Distribution
• Page 1 of 1
Re: Power Distribution
Neat, but eye-wateringly expensive...
... how about something like this:
https://www.amazon.co.uk/Mercury-Remote-Control-Socket-Adaptors-Black/dp/B0051NIJA4/ref=pd_lpo_107_t_2/258-6546722-5801461?_encoding=UTF8&pd_rd_i=B0051NIJA4&pd_rd_r=237eec2c-af71-4ec2-8491-bbc97b82467d&pd_rd_w=39k7E&pd_rd_wg=ri6Sq&pf_rd_p=7b8e3b03-1439-4489-abd4-4a138cf4eca6&pf_rd_r=PB1CN7VSBZFB4Y8ZMZ8Q&psc=1&refRID=PB1CN7VSBZFB4Y8ZMZ8Q
Multitudinous variations on this theme available...
I've used such devices in several different applications.
- Mike Stranks
- Jedi Poster
I use something very similar to that Penn power switcher, and it is very good from a practical point of view... except that I've had some trouble with the switch contacts welding themselves closed due to the huge in-rush currents of devices with SMPS power supplies -- wall warts, line lumps, and internal supplies.
As a result, I've had to replace switches fairly regularly -- until I decided to re-engineer the design with solid-state relays controlled by the panel switches!
The Penn unit might have switches better able to handle the inrush currents... but it would be worth asking the question before purchase!
An alternative that actually works very well indeed is to use Energenie remote switched four-way plugboards:
https://www.amazon.co.uk/Energenie-Trailing-Controlled-Protected-Sockets/dp/B003JT088S/ref=pd_sbs_60_3/258-5345153-1241418?_encoding=UTF8&pd_rd_i=B003JT088S&pd_rd_r=7b83f578-30eb-4c90-ac6c-18a65a5fd879&pd_rd_w=5q2Gy&pd_rd_wg=4d1a0&pf_rd_p=2304238d-df78-4b25-a9a0-b27dc7bd722e&pf_rd_r=QAEG0TQ5FDEJ0ECFE87H&psc=1&refRID=QAEG0TQ5FDEJ0ECFE87H
Hugh Robjohns - Moderator
Hugh Robjohns wrote:An alternative that actually works very well indeed is to use Energenie remote switched four-way plugboards:
I hadn't really considered this til the recent thread on the subject as I've been perfectly happy with my individually switched 6 gang but now you've given me a technically valid reason to swap it for a remote controlled one.
It's a pity really because reaching for and hitting those switches has been the only excercise I've been getting recently.
Ho-hum.
- shufflebeat
- Jedi Poster
Yes, those wireless mains switches are really handy things. You can get individual ones with a numbered keypad and the ones I have have an "All Off/ All On" button as well.
I have an elderly Sony 32" FSTV on the wall that serves as monitor for my living room PC but it sometimes dose not come out of standby, a mains cycle fixes it for a week.
Beware the very cheap diss' strips with 'surge protection' and filters. Some are wired such as to make the ground conductor dirtier!
- ef37a
- Jedi Poster
That's a handy lot of comments, thanks - call me a Luddite but I still don't love relying on remote controls for things in the studio if I can help it, I still like buttons that go 'Ka-Chunk...' if I can.
kinglouis - Regular
kinglouis wrote:That's a handy lot of comments, thanks - call me a Luddite but I still don't love relying on remote controls for things in the studio if I can help it, I still like buttons that go 'Ka-Chunk...' if I can.
This is mains power chap and the switches are relays...get over yourself!
- ef37a
- Jedi Poster
Thanks Dave, I appreciate the consideration although I’m not sure what I’m supposed to be getting over - it’s my studio, if I favour switches over remotes that is my lookout.
kinglouis - Regular
ef37a wrote:Beware the very cheap diss' strips with 'surge protection' and filters. Some are wired such as to make the ground conductor dirtier!
Are you referring to their habit of adding chokes in series with everything Dave?
Martin Walker - Moderator
Martin Walker wrote:Are you referring to their habit of adding chokes in series with everything Dave?ef37a wrote:Beware the very cheap diss' strips with 'surge protection' and filters. Some are wired such as to make the ground conductor dirtier!
No Martin it is the practice of connecting two capacitors in series across the live and neutral and then taking the centre to earth. Yes I know earth and neutral are really the same thing but supplies that just have one cap either side of the choke are said to be cleaner.
In any case, waaaay ago we found that after the introduction of the Silicon transistor you needed the spike filter on the FRIDGE not the kit getting hit!
Oh! Do you mean an inductor in the EARTH wire? No, don't want one of them, no Sir!
- ef37a
- Jedi Poster
