Hi gang.
I have an old Shure headset,
Shure wh20tqg
https://www.thomann.de/gb/shure_wh20tqg.htm
Which, according to this advice piece,
Shure advice:
https://service.shure.com/s/article/con ... uage=en_US
I can convert for wired use. I'm considering putting this transformer,
150/150 xformer:
https://uk.farnell.com/oep-oxford-elect ... dp/1689033
In a belt-clip box, maybe swapping the mini xlr for a regular one.
However, I also have an old BSS ar133 DI box (with an XLR unbalanced input) that I suspect might serve the same purpose.
Any thoughts or suggestions before I break out the toolbox?
Adapting a Shure headset for wired used.
• Page 1 of 1
- shufflebeat
- Jedi Poster
Re: Adapting a Shure headset for wired used.
I think you could make life a lot easier for yourself by simply cutting off the mini four-pin connector and soldering on a male XLR3. Job done!
The dynamic capsule is inherently balanced, but because your specific model is intended for use with a budget radio pack they have wired it for an unbalanced output purely in that mini-plug. Hence all the warnings about phantom power and the shenanigans with a transformer.
None of that is required if you don't want/need the mini-plug connectivity. Just hack it off and solder on an XLR3m -- red wire to pin 2, black wire to pin 3, screen to pin 1.
Hugh Robjohns - Moderator
Thanks H, I shall root around (carefully) in my tool box for Occam's razor.
- shufflebeat
- Jedi Poster
