Stereo Reverb from the US to use in UK studio
Postby recordplay » Wed Dec 23, 2020 7:10 pm
Hi All,
Any advice on rewiring the US to UK adaptor if poss please?
Realistic Stereo Reverb - Arrived with the standard US 2 prong plug
Not to sure which is hot and neutral or whether its even safe to whip of the plug and wire a UK plug to it. Sure I rememebr this is ok but just wanted to check as I'm not sure which is hot as both prongs and wires look the same??
recordplay
Re: Stereo Reverb from the US to use in UK studio
Postby Kwackman » Wed Dec 23, 2020 7:16 pm
WHOA!
First check if the unit can take 240V and what (if anything) needs done to safely switch to 240V.
Kwackman
Postby recordplay » Wed Dec 23, 2020 7:20 pm
Ahhh ok - Will check this now.
recordplay
Postby recordplay » Wed Dec 23, 2020 7:24 pm
Manual says power requirements for the unit are 120V AC 60Hz
Presuming I need it to be compatible with UK 240V 50Hz - Any advice on whether this will be ok with UK plug or do I need to do anything or mod the unit
recordplay
Postby Kwackman » Wed Dec 23, 2020 7:27 pm
Not sure, it might need a transformer, but hopefully cleverer people will be along shortly....
Excuse the "granny-suck eggs" nature of this, but in the meantime, DO NOT PLUG IT IN!
Kwackman
Postby The Elf » Wed Dec 23, 2020 7:30 pm
DO NOT PLUG IT IN! AND DO NOT CUT OFF THE PLUG!!!!!!!!!!
You need a step-down converter - 240V to 110V.
Something like this: https://www.amazon.co.uk/Step-Down-Converter-230-110v-100W/dp/B000L99ZJ2/ref=sr_1_18?dchild=1&keywords=240v+110v+adapter&qid=1608748061&sr=8-18
Better to leave to the US plug on, since it will prevent you, or anyone else accidentally plugging it into a 240V outlet.
Postby Hugh Robjohns » Wed Dec 23, 2020 8:02 pm
As the Elf says,
DO NOT REPLACE THE PLUG!
But do buy a decent step-down transformer to provide 110VAC.
Postby James Perrett » Wed Dec 23, 2020 8:07 pm
Also be prepared for the transformer inside the reverb to hum. If it is running close to its maximum rating then running it at 50Hz instead of 60Hz will stress it further. It will probably be fine but it is worth listening out for hum when you first plug it into the adaptor like the one that Elf linked to.
Postby Hugh Robjohns » Wed Dec 23, 2020 8:11 pm
Just for clarity, I think James means acoustic hum (or buzzing), not hum on the audio itself!
Postby Martin Walker » Wed Dec 23, 2020 8:14 pm
Hugh Robjohns wrote:Just for clarity, I think James means acoustic hum (or buzzing), not hum on the audio itself!
I agree, although it did occur to me that if the PSU smoothing capacitors were designed to be 'topped up' at 60Hz, ripple might be slightly higher when fed by 50Hz ;)
So audible hum 'might' also be an issue, although it's unlikely.
Postby CS70 » Wed Dec 23, 2020 9:56 pm
recordplay wrote:Hi All,
If it's not switchable power supply, you need a step-down transformer. They're not expensive and quite common to use with US kit.
EDIT: didnt read the other replies, see I'm late to the party :)
Postby James Perrett » Wed Dec 23, 2020 10:05 pm
Yes - I meant acoustic hum. This acoustic hum is a very common problem with US designed gear - even if it claims to work on European mains supplies it seems that US designers often don't take the different frequency into account. And expensive gear isn't immune to this problem either.
Postby Hugh Robjohns » Wed Dec 23, 2020 10:30 pm
True dat.
Postby ManFromGlass » Wed Dec 23, 2020 11:30 pm
A friend lent me his Foster recorder he brought back from the UK many years ago. It also had some kind of external transformer. Somehow I hooked it up wrong and turned it on when the musicians arrived.
Session cancelled, apologies on my red-faced part and it took a month to get it repaired.
Postby recordplay » Sat Jan 09, 2021 6:38 pm
Thanks Elf, Martin, Hugh and James + everyone
I bought the step down transformer which works a treat! Its bloody heavy and does have a loud acoustic hum. It’s a bit annoying but the reverb is an absolute joy so I’m really pleased with it. Thank you all!! Ps highly recommend the reverb unit
recordplay
