Here Is the room :
blinddrew wrote:Yes indeedy. Sound treatment can be DIY, affordable, and fairly straightforward. Sound proofing is difficult, expensive and oh-so-easy to get wrong.
Recordings well... I'm doing a lot of genres, mostly alone at the moment, ranging from electronics to symphonic with metal in-between. Instruments are a midi keyboard for basically all instruments except drums (which a v-drums too), guitar and bass, singing (for which I suppose it's best to buy a separate shield?) a few extras percussions and small instruments (harmonica, kalimba, etc). But it's mostly directly plugged in instruments usually. The goal is here is mostly focused on getting a neutral sound I'd say.What sort of recording do you do? Some more information about your objectives would be useful!
Chrismos wrote:Thanks for the welcome :D
Yeah sorry English im my second language and I mixed my words here. The right term was actually sound treatment not soundproofing.
Basically get a "faithful" sound, that's not drowned in reverb, from the monitors.
I didn't knew about this, pretty cool, thanks!Music Wolf wrote:and where best to place, bass traps / broad band absorbers and start with the ‘first reflection’ or ‘mirror’ points (imagine sitting in your mix position and placing a mirror on the wall either to your side or above your head. The point where you would be able to see a reflection of your monitors is where you should place your absorbing panel.
That's good to know!As the other guys have said, acoustic treatment i.e. to obtain a more neutral sound will be much easier to achieve. Looking at your picture I would say that you are starting out with a good layout (symmetry).
I can/planned to put some low shelves in here, maybe this will help absorb a tiny bit...but yeah if I don't I'll definitly think about bass traps here.You will need to experiment but, if it were me, I would be thinking about filling the small space where the sloping roof meets the floor with bass traps. This may not be the best position but it is probably space that is not easy to use for anything else.
Yep mixing. I knew about the off the wall thing, I also read something about how you should be place about 1/3rd of the room if possible In thinkCS70 wrote:I assume you will be using the room also for mixing? In this case, first pick your monitors position (make sure the speakers point along the longest axis, and have the desk a little off the wall if you can).
Well...that's already a lot to add and can certainly help, thanks for the list.Then the classic "shopping list" is : absorbers at mirror points from the speakers (google), bass traps in the corners, absorbers at the wall facing the speakers, absorbers/bass trap behind the speakers and trap on the ceiling.
