I think it has to do with impedance.....any help is greatly received.
Please see photo.
Hugh Robjohns wrote:If you want to reverse engineer it, you'll need to work out a full schematic, either visually, or with metering, or both.
N i g e l wrote:Those cylindrical melf resistors look a right fiddle. Why choose them? what are their special properties (apart from rolling off the bench) ?
Animalbeats wrote:However, can you dumb it down for me please
1 small smd resistor....I believe for RF frequencies...?
2 smd Capactors linked in series.....Which I think are to do with impedance?
2 smd Resistors linked in Series.... they have double black lines so I believe is zero Ohms?
And I can't see any further track where the signal goes into an electrolytic cap then a WIMA before going off to an op-amp, why could this be?
