Animalbeats wrote:However, can you dumb it down for me please
No... Because you don't have sufficient circuit detail to draw any conclusions at all
1 small smd resistor....I believe for RF frequencies...?
In what way 'for RF frequencies'? What makes you believe that? What would a small SMD resistor be doing wih RF frequencies! How would RF frequencies be reaching that resistor?
2 smd Capactors linked in series.....Which I think are to do with impedance?
Affecting impedance in what way? Why!
2 smd Resistors linked in Series.... they have double black lines so I believe is zero Ohms?
Possibly... I'm not entirely clear which resistors you're talking about... But I suspect your ring identification might be incorrect.
And I can't see any further track where the signal goes into an electrolytic cap then a WIMA before going off to an op-amp, why could this be?
Because its a multilayer board? It certainly isnt common to have an electrolytic feeding a smaller capacitor, so I would suspect you've misunderstood the circuit topology.
Can I clarify, please, what is your level of understanding audio electronics, and exactly what are you trying to achieve?
