At this stage of the build i have some questions regarding the shape of the room, acoustics etc.
details: Height - 83"
Width - 98"
(longest point) Length - 627"
(Shortest point) Length - 462"
The loft has a pitched roof and because of the width I've decided to place my rear ported speakers along the shortest wall towards the exit (left) and storage area (right). There are going to be 3 windows. the roof joist will be insulated as per regulations and covered with plasterboard. The whole room is timber frame, insulation, plasterboard, plaster. The floor is insulated then 20mm chipboard tongue and groove, there will be laminate flooring too.
Questions:
1. the pitched walls are symmetrical, would angling the plasterboard slightly on one side be beneficial ?
2. What problems will i incur adding this much desk space and how can i deal with it, should i mount anything to the top of the desks ?
3. The speaker wall is solid brick, the cavity between here and the outside wall isn't insulated so there will be a layer of Celotec and then plasterboard. should i put anything else behind the plasterboard or deal with all acoustic issues once the room is completed?
4. Is there anything else i can do (on a budget) to make this room behave better before its all finished/put together ? or should i just get it all finished and deal with any issues afterwards with DIY broadband and bass traps ?
I have been researching these topics and there are lots of similar articles, i will be calibrating my Yam Hs8's as best i can with the controls, running eq wizard and creating my own broadband and bass traps further down the line but if there is anything i can do now to make it better i'd like to know.
i'm firing this out there to see what i can learn from you guys directly. if there is anything else that i haven't mentioned that you think would help i'd like to know :thumbup:
Apologies for the questionable room schematic and for repeating myself. :lol:
Edited to make image links point to the images themselves rather than the imgur page - JP
