I would like to try and make my own audio cables, suggestions for where to get the parts?
Page 4 of 4
Re: I would like to try and make my own audio cables, suggestions for where to get the parts?
PostPosted: Thu Feb 25, 2021 12:54 pm
Tee hee... been there and done that myself too... That's definitely one where you need to go away and have a cup of tea, then come back refreshed and snip off both ends and start again...
PostPosted: Thu Feb 25, 2021 1:07 pm
by Luke W
I'm vaguely recalling once having to desolder a connector because of the old "boot on the bench" issue, only to clean it all up, get distracted by something, and then solder it straight back on without the boot again :headbang:
Why I'm admitting it I don't know.
PostPosted: Thu Feb 25, 2021 1:28 pm
You think an XLR is bad... try discovering the boot on the bench when you've just soldered on a 21-pin Amphenol multicore connector (for one of the BBC's weird 7-way multis), complete with Hellerman rubber sleeves on every connection... ...
PostPosted: Thu Feb 25, 2021 2:07 pm
by ef37a
Now t hen...Many a 15A lighting plug got the rubber case cut with a Stanley knife because we
forgot to put it on the cable before we wired the plug! (bit o black lekkie's tape, nobody could tell!)
PostPosted: Fri Feb 26, 2021 2:05 am
by Martin Walker
ef37a wrote:Now t hen...Many a 15A lighting plug got the rubber case cut with a Stanley knife because we
Shush - don't give all our secrets away Dave!
