Floating Floor
Re: Floating Floor
Postby Doublehelix » Thu Nov 25, 2004 12:10 am
Thanks Paul...great post.
I have been struggling with this whole control room/live room issue, and have another thread where I talk about some of the issues:
How Far do I need to go thread
Certainly cost is an issue as far as materials and time, but I want to make sure that whatever money and time I do invest is well-spent. As Max says in the other thread, "do it once, and do it right" (or words to that effect).
Doublehelix
Re: Floating Floor
Postby Paul Woodlock » Thu Nov 25, 2004 12:25 am
Doublehelix wrote:Thanks Paul...great post.
And I couldn't agree more with Max here. Which means calcs for floating floors ;)
If you haven't seen it already, take a look at my studio build diary. I've been through a lot of the things you're intending, and you may find the practical experience useful
Link in my studio diary thread I just created in this forum :)
Paul
Paul Woodlock
Re: Floating Floor
Postby Doublehelix » Thu Nov 25, 2004 3:10 am
I have indeed seen your diary, and have followed it off and on for a while. Great reading for those that have not seen it!
I am certainly nowhere near building anything on that scale...the way you have floated the cement floor is beyond belief! My needs are much more modest, and will be in a basement, so I am not worried about outside sounds or isolating to the outside world, but I just want a comfortable environment to track and mix, and get myself separated from the live room.
Doublehelix
Re: Floating Floor
Postby Paul Woodlock » Fri Nov 26, 2004 4:38 am
Doublehelix wrote:I have indeed seen your diary, and have followed it off and on for a while. Great reading for those that have not seen it!
:) I can tell ya that learning how to do it, and then designing it, caused the death of far more brain cells than actually building it.
The only hard bit was pouring the concrete. You have to be FIT to shovel 6 tons of concrete around. And I am NOT FIT :)
The worst was pouring the first supporting slab of concrete. I'd never laid a concrete slab before, and while screeding it flat I crouched down, and soaked my a55 with wet concrete for 2 hours. I later discovered the concrete ( strong alkali ) had burnt the skin of a 6" diameter area on my a55. it fvcking hurt for weeks!! I've still got a bad scar :frown: :)
Well, if you have modest Isoaltion needs, and the main gaol is isolation between the two rooms....
First investigate if the original floor can be disc cut to decouple the rooms without causing structural problems/distasters. If it doesn't, then do it. It won't cost much, but is VERY DUSTY.
Then whether you disc cut or not, you should build your inner rooms with the biggest air gaop you can afford between the rooms, and use as many layers of drywall on your walls and if possibel ceiling as you can afford.
Floating the floor will lose you room height anyway. And to do it to any degree of success will cost you a LOT of money.
Paul
Paul Woodlock
