How common is dovetailing?
Page 1 of 1
PostPosted: Sat Feb 06, 2016 5:37 am
by wuubb
It's something I've recently discovered and have actually found myself using quite frequently in my compositions, most often in fast, technical sections in an attempt to give wind players breathing room (I myself am I trumpet player so I understand that we wind players need oxygen ).
I've seen it occasionally in music that I've played, but not that often, but could that be just because I'm a brass player? I'm just curious if it's a good technique to use or if all the really good composers use it.
Re: How common is dovetailing?
PostPosted: Sat Feb 06, 2016 11:34 am
by Exalted Wombat
It's very common.
PostPosted: Sat Feb 13, 2016 2:05 am
by permanent_daylight
In orchestral music it would be hard to find a piece without it...in my experience at least.
It is generally something i try out to make things more interesting. Its a good way of adding counterpoint.
PostPosted: Sun Feb 14, 2016 8:59 pm
by artzmusic
It's used very often in instrumental jazz but not for the same reasons as for woodwinds. After the final "head" of the song each player will take his own 2 or 4 measures dovetailed to the previous player until each has added his final signature to the tune then out. A way of each player to give his final 2 cents worth!
Rick
PostPosted: Tue Oct 16, 2018 6:58 pm
by TheMiller
wuubb wrote: I'm just curious if it's a good technique to use or if all the really good composers use it.
I'd turn that on its head... If someone doesn't know that wind players need to breath, then they are not a good composer.
PostPosted: Thu Oct 18, 2018 10:00 pm
by ConcertinaChap
TheMiller wrote:If someone doesn't know that wind players need to breath, then they are not a good composer.
My wife learned that the hard way, fortunately while she was still at uni.
