Standard chord notation
Re: Standard chord notation
Postby starman9 » Sun Sep 16, 2012 8:21 pm
I have only dipped into bits of this thread, so forgive me if what I'm about to type is besides the point!
It is NOT at all true that mixing sharps and flats within the same chord should be avoided. The relevant rule here is that you should use the notes within the harmonic chromatic scale of the key you are in. So, for example, if the piece is in C major (or its relative minor, A minor) you would use the C harmonic chromatic scale. ie. C Db D Eb E F F# G Ab A Bb B.
This rule is actually extremely cool as it ensures that intervals retain the same VISUAL relationship in different keys. So a piece looks how it sounds. Simples! I should add that rules are made to be broken and there are definitely times when this one needs to be...
I can explain how to work out the harmonic chromatic scale easily for any key... but dinner's ready so will have to return later to do this!!
starman9
Postby starman9 » Mon Sep 17, 2012 10:45 pm
So here's how to find the harmonic chromatic notes for any key:
We need to start with just the note letters only. Lets say we want to know the correct chromatic notes for Db major: Our tonic letter is D, we then need 2 notes of the next letter (E), 2 of the next letter (F), 2 of the next (G), then just 1 of the next note letter (A) as it is the 5th note of the major scale, then 2 of the next letter (B) and finally 2 of the the next letter (C). So putting all those together with whatever sharps or flats give us a chromatic scale we get: Db, Ebb, Eb, Fb, F, Gb, Gnat, Ab, Bbb, Bb, Cb, C.
You just need to use the tonic note letter once, the letter of the fifth of the major scale once, then all the others, twice. That's it!
One beautiful thing when in Db is that you don't use E natural, you use Fb. This means that (for example) a jump between the tonic and the minor third has the same relationship on paper as if we were in D major, which it wouldn't if we used E natural.
In some keys there are both flats and sharps used at the same time. eg. the chromatic notes for G major are: G, Ab, A, Bb, B, C, C#, D, Eb, E, F, F#.
Hope that makes clear why it can be fine to use flats and sharps together.
I can at times veer away from keeping to the harmonic chromatic note names when in the world of diminished chords or when loitering in an other key that has not been reflected in the key signature.
starman9
Postby Exalted Wombat » Tue Sep 18, 2012 11:41 am
On a more pragmatic level - if you're writing something that will be heard as a major or minor triad - something you might write a chord symbol above - make it LOOK like one too! A Db chord in the treble clef will have a note in the space under the stave, then notes in the next two spaces. It will LOOK like a triad. So no question - the middle note will be some sort of F, not some sort of E. F natural for Db major, Fb for Db minor.
Exalted Wombat
You don't have to write songs. The world doesn't want you to write songs. It would probably prefer it if you didn't. So write songs if you want to. Otherwise, dont bore us with beefing about it. Go fishing instead.
Postby damoore » Mon Nov 05, 2012 7:45 pm
Exalted Wombat wrote:On a more pragmatic level - if you're writing something that will be heard as a major or minor triad - something you might write a chord symbol above - make it LOOK like one too! A Db chord in the treble clef will have a note in the space under the stave, then notes in the next two spaces. It will LOOK like a triad. So no question - the middle note will be some sort of F, not some sort of E. F natural for Db major, Fb for Db minor.
Db minor is 8 flats. Fb is the 7th flat. So the Fb could not occur earlier than in the key of Ab minor. In Eb minor, for example, the bVII chord is Db major - with a natural F.
So I guess that chord can occur - in Ab minor - I was thinking that you would not choose to notate in Db minor, you would use C# minor instead, but notating in G# minor would be weird. In Ab minor, as Db is the iv, you can also use the (major) IV chord, so the distinction really is F versus Fb rather than F versus E natural.
As a practical matter, if your charts are copied by your average copyist (I should talk), and if the note ends up a little high, and somewhat dubious as to whether it is an E or an F, with the natural in front of it, I think most musicians would read it as an F. So you really don't want to write it as an E natural.
damoore
Postby The Pablo Augustus » Fri Apr 12, 2013 1:40 pm
windbag wrote:Sure, there are rules, but as in music engraving, the 'rules' can profitably be considered 'guidelines' on occasion. The acid test is making it clear to the musician so you get the result you want. For example, in music notation, extremely chromatic passages are often better notated in sharps going up and flats going down. Nothing to do with enharmonics, simply it's quicker to read, say, G, G sharp, A rather than G, A flat, A natural. But a 'genuine' scale should be notated so that you get seven different note names, even if it means double flats or sharps. By my reckoning, G harmonic minor would be G, A, Bb, C, D, Eb, F#, G. Liekwise, some chords look much clearer one way than another, which may or may not be theoretically correct. There are times when Eb and F# look right, others when Eb and Gb look better. Usually it turns out that the theory is 'better', but not invariably. Judgment is needed.
I don't think convention should be changed to help people sight read.
In fact good performers should be playing from memory anyway if you want to have
a chance at decent phrasing, especially in difficult keys.
One musician I respect the most is a young jazz cat. While his peers are off playing hip hop,
he has built a list of hundreds of standards and other tunes he can play in every key and all tempos.
Thats how jazz education used to take place....you'd get on the bandstand and they would call donna lee in a crazy key and BPM.
We've gotten so lazy these days!
I don't mean to criticize your post, it seemed the quickest to reply to on this page, I know you've all made many of the same points, just thought I'd add another musician's perspective.
The Pablo Augustus
Postby damoore » Tue Apr 23, 2013 11:06 pm
That's not at all how it often works. Playing in a pit, you get a large book and very small number of rehearsals and often short runs, so everyone is sight reading most of the time. Added to the fact that the books have all been copied by foot, and you need all the help you can get.
damoore
Postby Anonymousvn » Wed Jun 17, 2015 8:12 pm
Can you share Sammy Nestico's book 'The Complete Arranger'?
I very need it, I can give you 6 month vps 512mb for your website :)
Anonymousvn
Postby GuyBarry » Sun Jan 29, 2017 11:44 am
Hi - I'm just starting to write in a jazz idiom so I'm learning about sixths and ninths in addition to my existing repertoire of chords. However I'm finding the terminology a bit confusing.
With seventh chords, you get the following pattern
C seventh (C7) = C major + minor seventh
C minor seventh (Cm7) = C minor + minor seventh
C major seventh (Cmaj7) = C major + major seventh
C diminished seventh (Cdim7) = C diminished + diminished seventh.
In each case apart from the first, the type of seventh added is the same one as the name of the basic triad: minor for minor, major for major and diminished for diminished.
But with sixth and ninth chords it doesn't seem to work like that. You get
C sixth (C6) = C major + major sixth
C minor sixth (Cmin6) = C minor + major sixth
C ninth (C9) = C seventh + major ninth
C minor ninth (Cmin9) = C minor seventh + major ninth
If I want a C seventh chord with a minor ninth, then apparently it's called a "dominant minor ninth" and written C7b9 or C7-9.
This really threw me for a while since I couldn't understand why a so-called "minor sixth" or "minor ninth" chord didn't include the interval of a minor sixth or minor ninth. Why does there appear to be one system for the naming of seventh chords and another for the naming of sixth and ninth chords?
GuyBarry
Postby wireman » Tue Feb 06, 2018 10:28 pm
I know that this thread is long dead but it raised an old interest of mine.
A very long time ago as an exercise I created a website on this very topic, the goal was to learn how to create a site and play with programming, nothing more. It has been languising for years and uses Java which hardly anyone (including me) has enabled any more. I thought the applets were cool. you could enter notes on a "keyboard" and find the chord, or see chords in a guitar string/fret frame, they might not even work now.
I could create a more modern version of the site or application if it was of any interest, I assume someone has created a capable app for phones by now which would do the same thing.
ISee here
I don't know why I kept the site, can't let it go.
Note that I am not in any way an expert in music theory and have no formal training.
wireman
Postby mpsjazz » Tue May 07, 2019 12:14 am
David Etheridge wrote:Hi folks,
here's a standard system of chord notation taken from Sammy Nestico's book 'The Complete Arranger'. Having a standardised version of chord shorthand means less chance of confusion on sessions and gigs. I beleive that this version is the standard form used by all the top arrangers (Mr. Nestico is currently one of the major guys), so it's useful to know this. He got it from 'Standardised Chord Symbol Notation' by Cark Brandt and Clinton Roemer (pub. Roerick Music co, USA)
Here we go:
Major chords will be indicated thus: C (and not Cmaj or ma).
Sixth chords: C6 (not C (A) (addA) or similar).
Seventh chords with the flattened seventh: C7 (not C add Bb).
Minor chords: Cm (rather than Cmin, C- or similar).
Minor 7ths: Cm7 (not C-7, min7th or similar)
Major 7ths: Cmaj7 or Cma7 (not CM7, or C with a triangle, although some people use the latter).
9ths work in the same way as 7ths (not Cmaj7+9, add D or other confusing stuff).
Aug 7ths with a #5: C+7 (not C7+, C7 (#5) or C7+5).
Aug 9ths : C+9 as for aug 7ths.
Thirteenths: C13 (and not C7 (13), C7+6, C9 add A, etc).
Diminished chords: Co; the o is a superscript placed next to the top half of the C but I can't do that on this computer! (not C-, Cdim, C7o, etc).
Six nine chords: C6/9 (not C2/6, C13 (no7) or C6 add D).
Seventh with a flat 5 chord: C7(b5) (not C7-5, C7#4, C7(5b)).
Half diminished chords-a minor 7ths with a flat 5: Cmi7(b5), although you'll find some folks use a o with a line through it, like the phase reverse sign on your mixing desk (but avoid things like Cmi7-5 and Cmi7 5b).
Seventh with a flat ninth: C7(b9). (Avoid C9b, Cb9, C9-, C(add Db)).
Minor with a major 7th: Cmi(ma7). (Not Cmi add B, Cmi+B, C-7.
Raised ninths: C7(#9) (rather than C7(+9), C+9,! C7(b3) or C9+).
Sus chords: C7sus (not C7(sus4), C7 (add F), C7 (alt 4th), C7 (+4) or C7 #3)).
Augmented 11th chords can be C9(#11), (not C+11, C11+, C11#, C9+11, or C9 (b12)).
Note that the + sign is used to indicate augmented, rather than a substitute for a #. Some musos use the dash (-) to mean minor, dim, or even a flat. No wonder you can get confused :?
Try not to use lower case letters on your parts for other players: a badly written 'mi' could be read as 'mj': is it major or minor? Is it real or is it Memorex (hands up all those who remember that advert :D)
MA is never used by itself, only in Ma7 or Ma9. Just write the chord name alone for the major chord (eg: Cm/ C). I once had a fine time on a gig with a rhythm guitarist who couldn't work out major and minor chords, to chaotic effect on some tunes! :headbang:
So that's it for the present. Even with this shorthand, sometimes you've got no option than to write C13 #11 b9 b5!
:roll:
Best wishes,
Dave
I like that system, but it's not so universal as you say. I know many jazz pop and latin musicians who always use C-7 rather than Cm7 (for example) and sometimes there simply isn't room to write things like "dim" or "maj7" anyway. The iRealPro app is probably the most common tool now, and it doesn't favour the Nestico system - perhaps sadly. By the way, you speak as though Nestico is still around and writing stuff, but his arrangements must be over 50 years old now - maybe a lot more. I played them as a teenager and enjoyed them.
mpsjazz
Postby Exalted Wombat » Thu May 09, 2019 12:07 am
At 95, Sammy may not be writing as much as he used to, but he's still around and certainly didn't retire 50 years ago!
Exalted Wombat
Postby Jimmy T » Sun Jun 07, 2020 9:03 pm
Sammy Nestico's books are great but for the most up to date movement in jazz nomenclature, Jamey Aebersold has clarified things over the last 25 years and it's the most straightforward and easy to read quickly , ie clear method I believe.
His fellow educators such as Dan Hearll, Mike Tracey etc all follow this too. Things like a triangle for Maj 7 for instance, or + for # 5. It's just much quicker to see and clearer to write.
Jimmy T
Postby Wurlitzer » Thu Jun 11, 2020 2:39 pm
Clearly one has to know all versions, since there is no one authority determining what everyone will use. There aren't that many and the important thing is understanding the chord and its implications - ie, what to play for a major 7 chord and how it affects any line you play over the top of it, not whether it's written M7, maj7, (maj7) or with a triangle.
Given a choice, I also prefer symbolic notation such as triangles for major 7 and circles for diminished, because they're quicker to reader and harder to confuse with other things. A triangle stands out against all the text around it and can only mean one thing. When you see the text "maj7" next to a chord root, if it's in a small font then you could mistake it for "min7", "maj9" or whatever. Or even if you get it right, but have to stop and squint for a few seconds to do so - what's the point, when you can just have a nice simple triangle instead and no confusion?
That's the point at the end of the day - it's a tool to get the information across quickly and accurately, so you can reserve the rest of your brain for actually playing the music.
Wurlitzer
Postby wireman » Thu Jun 11, 2020 7:29 pm
I'm used to circle for diminished and + for augmented but don't think I have ever seen triangle.
The strangest use of triangles is perhaps the US shape-note system.
wireman
Postby Sam Spoons » Thu Jun 11, 2020 11:04 pm
I've been using a triangle for maj7 for 40+ years and '-' for min, O with a slash for half diminished as well as the others you mention. I've even come across Nashville charts on occasion. When you know them they definitely make charts more readable (just as well for me as I have negligible sight reading skills WRT dots).
