Modes: don't you just love 'em?
Re: Modes: don't you just love 'em?
Postby Ian Stewart » Fri Jun 30, 2006 10:23 am
rmacd wrote: one that seems to be coming about is schenkerian analasys but I have absolutely no idea what it is or what it's supposed to do :bouncy: slightly OT but any ideas??
You're not alone in this, see the recent thread on it.
Ian Stewart
Postby The Right To Arm Bears » Mon Jul 03, 2006 11:07 pm
For me there's nothing that clever about modes - simply starting and finishing a major scale on the various intervals from the root isn't rocket. I see such long winded explanations of modes it then makes me forget what they actually are :headbang:
Support your right to arm bears!
Postby Bozzieman » Wed Jul 12, 2006 3:29 pm
I've always found that "Dead can Dance" had a special sound ...
And I'm guessing it had something to do with the mode they composed their music in ...
Any one any idea what mode they used ? :headbang:
Bozzieman
Postby apefist » Thu Nov 23, 2006 10:55 am
I've always found modes to be fascinating, especially the east asian modes.
I'm not sure if these have been covered under different names or terms, but for your consideration:
Balinese....C C# D# G G#
Chinese.....C D E G A
Egyptian....C D F G A#
Japanese....C C# F G G#
Hirajoshi...C D D# G G#
Iwato.......C C# F F# A#
Algerian....C D D# F# G G# B
Ethiopian...C D D# F G G# A#
East Asian..C C# E F F# A A#
Even though there is some overlap, I think the half-step forms the "sound" of these modes as opposed to western modes in which whole steps seem to dictate the scale's sound (for the most part).
apefist
Postby Conception » Mon Jan 15, 2007 4:44 am
Can Someone help me out with this one?
HWH5HWW
Or C C# D# E G Ab Bb C?
I think im blind cause i cant find which catagory that falls under. sounds kinda melodic minor but maybe i just dont kno wwhat im talking about :tongue:
Conception
Postby mrthingy » Wed Jan 31, 2007 5:17 pm
Hi,
I use modes when playing the guitar, but only as a way to remeber the fingering of sacles up and down the fret board.
What I'm interested in is how you compose in a mode, isn't it just the same as composing in a key? How is/how do you make F Lydian different from C Ionian? Isn't it just the same thing?
mrthingy
Postby Pabs » Wed Jan 31, 2007 9:27 pm
mrthingy wrote:Hi,
Try this:
Write a chord progression in F Maj and improvise over it using F Lydian/C Major.
Pabs
Pabs
Postby mrthingy » Thu Feb 01, 2007 3:14 pm
To be honest I didn't notice that much difference...
I found that playing the B in either mode was pretty bad (cou that just be that the chord sequence had a few Bb's in it?) and I played the same sorts of notes in both, similar licks around the e, f, g and a.
That was on guitar, then when I messed around on the keyboard I really found playing from F or C as a starting point made no differents at all in the sorts of things I was playing. Are you ment to keep it all in the same octave when you're playing modes on Keyboards/piano?
I'm not that good at analysis what I'm playing so it maybe that I just don't get it, but I'm still at a loss to think of modes as anything other that fingering patterns.
I do find that if I play in some modes, mixolydian for example, I get certain 'feel' but I think thats more down to the fact that I end up playing similar bits in that mode.
However, from your example, pablo, I guess I'm thinking of it wrong. When I use a mixolydian over something in the key of C, I would use G mixolydian. But seeing as you sugested F lydian over something in F it the idea maybe to use a mode from one key over a chord progression in another key.
mrthingy
Postby TP. » Sun Jun 03, 2007 5:19 pm
Ionian:
Dorian:
Phrygian:
Lydian:
Mixolydian:
Aeolian:
Locrian:
TP.
Postby TP. » Sun Jun 03, 2007 7:20 pm
Conception wrote:Can Someone help me out with this one?
HWH5HWW
Well since nobody's replied after all this time...
I don't have a name for it, but it looks like a mode that would be played over an altered dominant chord. But it's not written "correctly", i.e. the notation does not reflect the harmonic functions of the notes. If you write it as:
C Db D# E G Ab Bb C
...then you can see that:
C is the root of a dominant chord
Db is the flat 9th (really a minor 2nd)
D# is the sharp 9th (really an augmented 2nd)
E is the 3rd
---There is no 4th---
G is the 5th
Ab is a flat "13th" (it would actually be a 13th if it were an octave higher, otherwise it's a sharp 5th but it would be called G# if it were a fifth)
Bb is the minor 7th.
There is a scale called "Altered scale" that would be:
C Db D# E Gb G# Bb C
It fits over "altered" dominant chords, with the flat and sharp D ("9th") and G (5th).
The mode you have written looks close to that. The only difference is the perfect 5th in your version.
Probably someone somewhere gave it a name and put in in a scale book.
TP.
Postby guy999 » Mon Jul 16, 2007 2:49 pm
This is all very nice. But how do I go about putting these modes into guitar solos/riffs? If its in say, C, do I just pick C modes dependant on the underlying chords, and will get a different "sound"/"voicing"/whatever dependant on which one I play? Or if you are in C do you play D dorian, E phrygian etc. (though surely they would sound the same?) As for fingerings on guitar, from what I have read above, I take it you can play any mode in any key without moving position on the fretboard?
Any help would be appreciated. I have not fully understood these for years, just been turning a blind eye. I listen to a lot of progressive music and would like to finally try and comprehend what they are doing melodically (and i'm bored of pentatonic minor) :smirk:
guy999
Postby Pabs » Mon Jul 16, 2007 6:17 pm
Examine this example:
'So What' by Miles Davis (download it off iTunes if you don't have this recording) is rooted around D min but the key is NOT F maj/Dmin. The Key is ACTUALLY C Maj. The D min chord is the ii chord not the vi chord.
The reason the Key is C Maj is because they are all improvising in C Major...which when played over Dmin sounds Dorian. Had they been improvising in Bb Maj over that D min chord it would have sounded Phrygian not Dorian.
To be honest you don't really need to learn modes the same way you learn scales. If you can play the C maj scale all over the neck of the guitar you already have the ability to play D dorian, E phrygian F lydian etc.... its just a different start and end point or root.
It may benefit you to associate different chords derived from the same scale with modes.
eg G Major Scale
G Maj - G Ionian/Major
A Min - A Dorian
B Min - B Phrygian
C Maj - C Lydian
D Maj/D7 - D Mixolydian
E Min - E Aeolian
F# Dim - F# Locrian
Pabs
Pabs
Postby leslawrenson » Mon Jul 16, 2007 6:24 pm
pablo fanques wrote: To be honeest you don't really need to learn modes the same way you learn scales. If you can play the C maj scale all over the neck of the guitar you already have the ability to play D dorian, E phrygian F lydian etc.... its just a different start and end point or root.
Pabs
That's very true. But, of course, by understanding the modal system, and also knowing how to play all the other scales all over the neck, you can learn to centre your sound around a particular mode. So that, for example, if you want to stay in the Dorian mode, you can alter your scalar playing whenever the band change chords. So the band stay in the one key, but you exploit the chord change to retain the Dorian signature (ie you effectively start playing in a different key).
Jesus! I used to be heavily up on this in the days when I taught guitar. I was heavily into the modal "centre" style of playing espoused by Joe Satriani back in the early 90s, and I used to get really anoraky on this very subject.
I'd glad to report that I've lightened up a lot since then.
leslawrenson
Postby leslawrenson » Mon Jul 16, 2007 6:53 pm
mrthingy wrote:Hi,
The common mistake that seems to be made with modes (and there are a couple of persons in this thread who make the mistake) is that you play modes within the same key. But that misses the whole point of modes. They are not to be used simply as a means of telling you which note to play from (that is used merely as a means of demonstrating the harmonic relationship between the intervals).
So, for example, there is no point playing A aeolian in the key of either Cmaj or Amin, since all you would really be doing is playing within either the key of Cmaj or Amin. To hear (in our eg) the sound of A aeolian, you need to contrast it with another key. So, for example, you might be playing a solo in the key of Gmaj, in which the A tone is dorian minor. But, if you play the notes of the Cmaj scale in your solo, but playing around the A tonality, you will be playing A aeolian, and it will be the flattened F sharp (ie looking at it from the point of view of Gmaj) that will give the "aeolian" sound to your solo, since it will contrast with the key (ie Gmaj) over which you are playing. That is to say, the western listener will be expecting you to play F sharp in the key of Gmaj, but my playing the flattened F sharp (whilst centering your solo around the A tonality) your solo will take on an aeolian quality.
This is a very simple example, but it centres on the key point that you can only really hear the modes by playing them "out of key" (for want of a better expression).
And of course, some modes sound dreadful over some chord changes cos the keys just have too much discordance in them. They are just a little too "way out there" (if you know what I mean!). As with everything, though, it's all a matter of practice, and that's what makes knowledge so powerful, cos it gives you the ability to dictate to the music, rather than leave the music to dictate to you.
leslawrenson
Postby Rousseau » Mon Jul 16, 2007 11:08 pm
Yes modes are essentially simple, but it helps from the outset to erase ANY notion of key, dominant, major, minor from the discussion (except, of course, that major and minor are modes, but that's another story).
1st principle. You can play all church modes (ie all the ones with Greek names (albeit incorrectly named but that's another story)) using only the white keys on a keyboard.
2nd Principle. Each mode has a governing characteristic. Let's take Dorian. The thing that distinguishes the dorian mode from other modes (both theoretically and sonically) is the sixth degree of its scale; it is always a major sixth from the final. If you start on D, you'll be hearing a B natural. It is this interval that gives the mode its flavour, and it is this interval which of course governs the harmony that will frame the mode. The Lydian mode is characterised by its sequence of whole tones (F, G, A, B) and its augmented 4th flavour.
3rd Principle. Change the final (or the bass note or drone) and you change the mode. For example, play c,d,e,f,g,a,b,c over a G bass and you're in mixolydian mode. Play the same notes over a F bass and you're in Lydian mode. Play the same over a B and you're in Locrian mode.
4th principle, you can't modulate with modes, since modulation is a tonal concept (which implies a completely different set of rules, hierarchical relationships and teleological objectives). Modes are essentially static.
Rousseau
