Using Notion 6 with Garritan Personal Orchestra 5 - no sound
PostPosted: Wed Mar 29, 2017 9:14 am
by Inversneckie
I recently bought Notion 6 and am pleased with it although it's a steep learning curve. I also have GPO 5 and used the Notion plugin manager to enable Aria. As soon as I did that Garritan Personal Orchestra appeared in the score set up page. I selected an instrument from the list and then tried to input into the score sheets using both the mouse and midi keyboard - no sound whatsoever! The result was the same whether or not the Aria player was activated. I checked the Notion mixer to make sure that it was not muted. I had another instance of a score sheet open using a Notion instrument and that worked fine with either mouse or keyboard input.
Any advice would be much appreciated.
