I can't figure out this synth lead
Postby mikemike1191 » Sat May 04, 2019 7:32 am
hey guys I know I'm new here, but I can't figure out the synth lead in this song. Whenever I play it on my keyboard it's almost like the notes sound to obvious he does something where he almost makes the melody sound so fluid like its barely rising in its pitch or notation. The closes I've gathered is that it's probably in C# minor or at least in that key. I can barely even tell what octave it's in.
If anyone has any ideas it would be greatly appreciated.. I've tried almost everything I can think of. Here's the song. Skip to 5;41 to hear the lead.
https://www.youtube.com/watch?v=NMIffSBwsDI
mikemike1191
Re: I can't figure out this synth lead
Postby BJG145 » Sat May 04, 2019 3:30 pm
Here it is played slowly:
https://soundcloud.com/qchord/synthsound/s-LKHBp
I don't know how to tell if it's Dbm or C#m 'cos I'm thick. But let's say it's in Dbm, then I reckon the notes would be:
Db Fb Gb Db
Db Fb Gb Db
Db Fb Gb Cb Db Cb Db Cb
Db Fb Gb Db
Db Fb Gb Db
Db Fb Gb Fb Db Fb Db Fb
(I expect you're right and it would be better to write it in C#m but I dunno why. The fluidity comes from it having a small amount of portamento dialled into a mono patch so the notes glide across.)
Postby Eddy Deegan » Sat May 04, 2019 4:20 pm
BJG145 wrote:The fluidity comes from it having a small amount of portamento dialled into a mono patch so the notes glide across.)
+1
It's the portamento that gives it that distinctive character that you wouldn't be able to reproduce just playing notes alone.
Some of my musical works.
Postby mikemike1191 » Sat May 04, 2019 6:42 pm
You guys are f'ing the best thank you so much for your time and help!
I knew about the glide but I think you nailed the notation.
mikemike1191
Postby mikemike1191 » Sat May 04, 2019 10:59 pm
Now I just gotta work on the wave forms and the effects, but honestly thanks for the help with the notes and glide. I thought I was using the glide before but I wasn't actually overlapping the notes so the pitch wasn't as fluid like you said
mikemike1191
Postby Eddy Deegan » Sun May 05, 2019 8:06 am
mikemike1191 wrote:I thought I was using the glide before but I wasn't actually overlapping the notes so the pitch wasn't as fluid like you said
Aha, that'll make all the difference :D
Postby mikemike1191 » Sun May 05, 2019 10:38 pm
Also any other tips on the effects would be amazing. I've been obsessed with this least for years.
mikemike1191
Postby The Elf » Mon May 06, 2019 7:01 am
Some synths only generate portamento when you play legato notes (an annoying feature, IMHO), but a decent synth should let you lock portamento on. Some have both, so check the settings.
Postby BJG145 » Mon May 06, 2019 9:37 am
mikemike1191 wrote:Also any other tips on the effects would be amazing. I've been obsessed with this least for years.
If you mean that lead sound, one thing I noticed is that the stereo panning is linked to keyboard tracking, moving further to one side as he plays up the keyboard...so when it glides between high and low notes, it also glides left and right.
Postby mikemike1191 » Fri May 10, 2019 8:38 am
Awesome tip thank you very much!
mikemike1191
