How to work the VSL Harp using VI PRO ?
Postby Gone To Lunch » Mon Nov 04, 2019 8:37 pm
Does anyone know how to work the VSL Harp using VI PRO ?
On p4 of the Harp manual it says :
“and if you like to keep your keyboard free for playing instead of switching, you can disable preset keyswitching and only use MIDI Program Changes. Vienna Instruments PRO also allows you to define a MIDI Control for Preset keyswitching.”
Great.
But it does not say how or where, and I can’t find it in the VI PRO manual either ?
How do I disable preset keyswitching so I can use MIDI control instead ?
Or are they talking about using Patch change, but that doesn’t come up in a menu in the VI PRO either ?
Gone To Lunch
Re: How to work the VSL Harp using VI PRO ?
Postby Gone To Lunch » Mon Nov 04, 2019 9:00 pm
Problem solved.
I was actually in an old VI, not VI PRO.
"Before climbing the ladder of success, make sure it is leaning on the correct wall."
Gone To Lunch
