Looking for feedback on a game music track
Page 1 of 1
PostPosted: Wed Aug 12, 2020 10:52 pm
by conkerzzz
Hi, I've made a game music track, but do you think it's worth putting in my reel or should I redo it with more care paid to theory? Are there any pain points that stick out to you? I'm fairly new.
Re: Looking for feedback on a game music track
PostPosted: Wed Aug 12, 2020 11:46 pm
by Martin Walker
Hi conkerzzz, and welcome to the SOS Forums! 8-)
This is a nicely constructed piece, and I can hear the game mood you're hoping for, but to me sounds suspiciously like something created using an Amiga Tracker program, with a limited number of available sample channels, which inevitably results in a slightly 'bitty' sound set of separate elements, rather than the orchestral mix you are presumably hoping for.
All the notes are there, yet without more expression during the performance (crescendos, diminuendos. rallentandos and the like) it will always sound like someone playing parts on a keyboard.
The overall sound is also rather dry and anaemic. Although you have a little stereo width there, and some reverb, there's not enough to 'glue' the sounds together into an ensemble, and the end result would be a lot more impressive if you spread out the sounds as they would be in an orchestral context.
Hope this helps, and keep up the good work!
PostPosted: Thu Aug 13, 2020 12:30 am
by conkerzzz
Martin Walker wrote:Hi conkerzzz, and welcome to the SOS Forums! 8-)
Wow thanks so much for taking a listen! I'm glad it's not a total disaster and that the mood comes across. So interesting that you mention limited number of sample channels and "bitty" sound as the inspiration came from Nintendo 64 games such as Goldeneye 007, so I take it as a compliment, haha. I believe those systems were rather limited and didn't sound like an orchestra but the fakeness charmed me. In the future I might do two versions, one with proper orchestral samples and an "N64-version"!
I will take on board your valuable comments, much appreciated. I think if that I went for a proper orchestral version I could do a better job at using reverb, stereo spread and the expression techniques you mentioned to glue it. I also have some more ideas in my head for "melodies behind melodies" that I'll try to enter into the sequencer, the hardest part!
PostPosted: Thu Aug 13, 2020 9:47 pm
by CS70
Yeah, straight out of the early 90s! I can almost see the largish pixels and the attempts at antialiasing on a limited VGA palette. All of which back the felt awesome.
Well done :)
PostPosted: Thu Aug 20, 2020 3:11 pm
by conkerzzz
CS70 wrote:Yeah, straight out of the early 90s! I can almost see the largish pixels and the attempts at antialiasing on a limited VGA palette. All of which back the felt awesome.
Well done :)
I'm glad it's in the ballpark. The 90's it is! I must say the composition process was a bit difficult for me as a noob. I suspect it was because I didn't decide on a key, so I "swinged it" some times. I think next time I will try to be more informed of the key center and the diatonic material I have to work with...
PostPosted: Sat Sep 12, 2020 8:55 pm
by shiihs
conkerzzz wrote: should I redo it with more care paid to theory? Are there any pain points that stick out to you? I'm fairly new.
Congratulations with your track. I actually liked it a lot (disclaimer: I heard it on crappy laptop speakers, so I only heard the "gist" of it, but what I heard sounded convincing). Don't worry too much about following theory. Theory is there to help you find solutions if yet get stuck, and to describe how other composers wrote their stuff. Most composers learn theory so they are better prepared to systematically violating it ;)
