Well, yeah, again, electric shocks from mics !!
Postby ghc » Wed Feb 06, 2008 7:21 am
Hi everyone !!
Ok, if you are interested(and it is, i'm advising to read through it, plenty of good info) i've posted this discussion before on 24/08/07 ''Electric shock from mic while touching guitar, ......''
I just came across the same problem a while ago, last week !!
My mixer was plugged in to a socket in the wall, so as musicians, but spread in different corners, different sockets (all on the walls).
And, to stop the mic from being electically charged, all i had to do was: Plug out my mixer which was going to a socket in the wall, and in the same socket (on the wall) i plugged in an extention lead, and then i plugged in the mixer in the extention+vocalists guitar ?!
Sounds strange to me but it worked !!
Could anyone explain to me (and to all of us) why did it work ?!
I just can't understand it !! Lost !! :headbang: :? :D
Thanks guys !!
ghc
Re: Well, yeah, again, electric shocks from mics !!
Postby Hugh Robjohns » Wed Feb 06, 2008 10:24 am
Assuming the guitar amp was properly earthed, then by plugging the guitar amp into the same mains extension as the mixer, you ensured their earths were at the same potential, and thus no shocks.
I suspect the socket that the guitarist was using originally had no earth, or a very poor earth.
There really is no excuse these days for not checking each and every mains socket used in every venue with a simple socket tester to make sure they are wired correctly and are safe to use.
It is also a much better idea to run everything from the same socket or adjacent sockets, to reduce the risk.
Hugh
Postby Sheriton » Wed Feb 06, 2008 11:07 am
Call me extremely pedantic...
It's very rare that a mic will ever give you an electric shock. It's almost always the fault of the guitar / amp; it's only by touching the earthed mic that this becomes apparent. It always winds me up when people blame the mics rather than the true cause...
Sheriton
There's nothing we can't face... Except for bunnies
Postby Paul Soundscape » Wed Feb 06, 2008 11:10 am
i dont think it has anything to do with the amp.
i played at the colston hall in bristol and i even had problems there, and my equipment is certainly earthed!
It was that our amps were plugged in to a different circuit to the mixing desk
Paul Soundscape
Postby Hugh Robjohns » Wed Feb 06, 2008 11:41 am
Paul Supersonix Studios wrote:i dont think it has anything to do with the amp.
To be fair, it is most usually a problem associated with a disconnected earth on guitar amps (to kill the hum, man!).
I'm glad to hear it, but can you be as certain that the socket you plugged it into is properly earthed, or that the equipment, sockets, mains cables and plugboards that everyone else uses are properly earthed?
The only way to be sure and safe is to test the mains sockets you plan to use before using them, and check that everyone's equipment is earthed correctly before allowing them to plug anything in.
Then there was a potentially lethal fault somewhere in that building. The difference in earth potential between sockets should be no more than a volt or two at most. To feel a shock when touching an earthed mic suggests that an earth was missing from the singing guitarist's rig. If that's the case, then he is playing on borrowed time.... :angel:
Hugh
Postby Paul Soundscape » Wed Feb 06, 2008 1:57 pm
yeah well as hundreds of professional touring chart topping artists play there every year you would have thought that it would be properly earthed? maybe not,
the reason i said it wasn't the guitar amp was because i was getting shocks(and i play bass and sing) and so was our guitarist(who also sings) and its never happened before?
Paul Soundscape
Postby Hugh Robjohns » Wed Feb 06, 2008 2:24 pm
Paul Supersonix Studios wrote:yeah well as hundreds of professional touring chart topping artists play there every year you would have thought that it would be properly earthed? maybe not,
The first rule of not dying is to not make assumptions like that. Faults happen. Things can change. When we rigged for some SOS seminars at the old Wembley Arena site, I found four faulty sockets in the same conference room -- a room that was used everyday by all and sundry. One socket had no earth, two were live-neutral reversed, and one just had no power. It happens! Often, the screws clamping the cables inside work lose or tarniosh and oxidise. Sometimes they weren't done up tight in the firtst place, and as the cable oxidises the connection goes high-resistance. That's all that's needed to make the safety earth next to useless! Sometimes someone else has had a major fault and the cable or the socket has been damaged but not reported to be fixed. Hence my advice to check them before using them.
Were both your amps plugged into the same mains extension plug board by any chance? Or the same wall socket? If so, you've probably just identified where the missing earth was.
Clearly, there was a serious and potentially fatal fault somewhere. It could have been the earths protecting the sound desk, or it could have been the earths protecting the guitar and bass amps.
In my experience, shocks when touching a microphone are almost always because the mic body is properly earthed but the guitar amp's earth is disconnected, so that the 'earthed' metalwork on the amp (and guitar string earthing) floats up to half mains voltage (115V).
You won't feel that while playing as long as you don't touch anything else earthed, but the moment you do, you'll get the shock.
Now the missing earth might not be because the safety earths in the amps have been deliberately disconnected -- it could just as easily be because a mains cable or extension board has been damaged, or the wall socket could be faulty, as I've explaiend.
It's a less common scenario, but certainly still one worth investigating, that it could equally have been the other way around -- the guitar amps were properly earthed and it as the mixing console earth that was at fault. In that case, the mic's body would have floated to 115V, but you would have got the same tingle effect through the grounded strings.
Sadly, without all the same equipment set up in the same room in the same way, we'll only ever be guessing what the actual problem was. But it would be foolish to dismiss it and not check everything you can carefully.
As I said, the location of that discontinuous earth (or earths -- there could be more than one fault here) could be at any of a variety of places. The wall sockets, the extension cables, the mains plugs, the mains cables, the pluig-boards, or inside the equipment itself. The only way to be sure is to check every single mains cable you used, every extension cable, and every piece of equipment.
In fact, this really is something you should do regularly anyway. Cables get snagged and cut, or tripped over pulling the wires from the plugs, and screw connections inside plugs can work loose and wires corrode and oxidise.
If they all check out okay, then it was probably the mains sockets in the venue -- it really isn't that uncommon! Buy a tester, and make a point of using it next time. it only take a few seconds. Also, to be almost completely safe, make sure you run all your own equipment through an RCD, and persaude all the others in the band (and FOH) to use RCDs too.
Hugh
Postby Paul Soundscape » Wed Feb 06, 2008 3:14 pm
ok thanks hugh that makes a bit more sense now, it was a while ago so cant exactly remember where we were plugged in to but yeah i always use RCD's now.
it only happened when we sang and touched our strings.
Cheers
Paul Soundscape
Postby Hugh Robjohns » Wed Feb 06, 2008 4:47 pm
Paul Supersonix Studios wrote:it only happened when we sang and touched our strings.
Yes, it would.
Normally, the strings are earthed through the guitar cable's screen to the guitar amp, and from their to the mains safety earth of the amp's mains lead.
The mic body is earthed through the mic cable screen to the mixer, and from there to the mains safety earth of the mixer's mains lead.
If one or other of those mains safety earths becomes high resistance or disconnected, then the mains input filtering of the amp or mixer will tend to pull everything connected to the now disconnected earth line up to half mains volts (115V in the UK and Europe).
If you are playing the guitar while touching the mic body as you sing, you complete a circuit, one side of which is earthed, and the other is sitting at 115V. it doesn't matter which way around it is -- which side is still earthed and which is floating -- the results ae the same.
If you're lucky it will just tingle unpleasantly. If you're unlucky there'll be a bang and the gig will come to a premature end... as will the person who formed the link in the circuit.
You said this only affected you and the guitarist, and that's often the case. Vocalists generally only touch the mic and nothing else -- so there is no circuit. Likewise keyboard players generally only touch plastic keys, so there's still no circuit.
The worst case scenario is when the circuit is formed across the hands -- one hand on the guitar strings, the other on the mic. That way any current flow is straight across the chest, through the heart, and is likely to stop the heart. One ex guitarist...
Hugh
Postby jamaicanDave » Wed Feb 06, 2008 5:41 pm
never happened to me b 4 but thanx 4 posting that thread...
it's gonna save me loads of time in the future...cause i'm sure it'll happen
jamaicanDave
Postby dmills » Wed Feb 06, 2008 7:40 pm
I could tell you a few stories about that venue, but probably had better not.
Most touring acts will plug distro into the heavy stage power tie stage right (good for 400A or so IIRC) and forgo the use of the random 13A points except for back stage tea and coffee.
That the earthing is a little suspect comes as no surprise (No reflection on the house crew, council run venue and Bristol council, well 'nuff said).
I would heavily advocate always testing before you plug in anywhere, in any venue and that the use of RCD protection on backline supplies is just good sense (along with FOH if you don't trust things).
Note that most simple socket testers cannot identify a neutral/earth reverse.
There are a scary number of dodgy sockets out there, test everything and be paranoid, it's good for you.
Incidentally, IME CEE form sockets are less likely to be miswired as people pay more attention to the 'industrial' power then they do to the domestic stuff (Good reason to use them if available).
Regards, Dan.
dmills
Postby Paul Soundscape » Wed Feb 06, 2008 8:14 pm
the engineer was a right pr*ck he just said "deal with it". in the end our guitarist just got so annoyed at the end of the set just smashed over the mic stand lol
Paul Soundscape
Postby DingoDave » Wed Feb 06, 2008 10:36 pm
Hehe my guitarist was getting static off his guitar in band practice dont know why it happend, he was also using a mic at the time and quite close to the amp and socket. It was amusing to watch when now and again hed jump in the middle of a song with a small yelp! :D
DingoDave
Postby Paul Soundscape » Wed Feb 06, 2008 11:06 pm
haha yeah its not fun if your being shocked after a 30 minute set my mouth was burning.
Paul Soundscape
Postby seablade » Thu Feb 07, 2008 2:18 am
Paul Supersonix Studios wrote:the engineer was a right pr*ck he just said "deal with it". in the end our guitarist just got so annoyed at the end of the set just smashed over the mic stand lol
You are completely within your right to walk out there.
NOTHING is worth the risk you just put yourself through(30 minutes???!!!!). If they have a problem with you walking out, tell them you will feel happy to have the local inspector come in and make sure the building is up to code and if that is the case you will come back. But until then something is very much NOT right there and they are endangering lives like that. Honestly the engineer that says, deal with it, to something like that needs to be fired on the spot. Maybe then he will learn not to screw with electrocuting people.
Seablade
NOTE: I am in the US, though I would imagine a similar safety inspection exists in the EU for such situations.
seablade
Next
