Intermittent radio mic
Postby shufflebeat » Sun Apr 10, 2011 10:28 pm
I've been, ahem, volunteered by my darling daughter (bless) to check out an intermittent fault (drop out) on a radio mic at her school. I've witnessed the fault a few days ago and it seems to be a definite cutting out rather than the odd missing syllable.
Not owning one myself I'll be guessing once I get beyond the usual. Can anyone describe any common problems or suggest what might be worth eliminating as a possible cause.
Muchos Grassy Ass.
shufflebeat
Re: Intermittent radio mic
Postby dmills » Sun Apr 10, 2011 10:36 pm
Are they using more then one?
The assignment of frequencies if multiple mics are in use gets a bit complicated.
Check the aerials, can they see the stage, are they in reasonably free space? Undamaged?
Try turning the squelch down a bit.
Are they replacing batteries before each show?
So many possibilities.
Regards, Dan.
dmills
Postby shufflebeat » Sun Apr 10, 2011 11:35 pm
Good start, that, you've just doubled my possible approaches. Cheers Dan.
shufflebeat
Postby Mike Stranks » Mon Apr 11, 2011 9:27 am
+1 on everything Dan's said...
... and don't overlook a non-radio-related cause... is the cable between the receiver and the desk consistently good?
... and to amplify Dan's comment on frequencies... check if the mic is UK-legal... if not could be a radio-frequency interaction with goodness knows what.
(See the JFMG website on what is UK-legal if you're unsure.)
Cheers! M
Postby DPoll » Mon Apr 11, 2011 9:32 am
Once you've tried the above. If your still having problems, next step is to move the reciever physically closer to the Mic. Also buy the best batteries you can get hold of. Older Mics tend to not like even a small drop in voltage from the battery.
I used a crappy vhf Mic last year for a kids camp and didn't get much more than an hour from the battery before drop outs became common and that was with duracells and the receiver about 8ft from the Mic.
DPoll
Postby seablade » Tue Apr 12, 2011 1:01 pm
TSH-Tim wrote:
We stock Shure UHF premier series and YES if you hold them at the bottom they cut out.
I assume by premier series you are referring to the UHF-R series.
See my point two then.
Seablade
Who is pretty familiar with those mics among many others.
seablade
Postby TSH-Tim » Tue Apr 12, 2011 6:36 pm
No i mean Shure UHF premier series ... UHF-R which is a load more money again :frown:
TSH-Tim
Postby TSH-Tim » Tue Apr 12, 2011 6:37 pm
What they offered us was a joke to say the least....
TSH-Tim
Postby seablade » Tue Apr 12, 2011 7:22 pm
TSH-Tim wrote:No i mean Shure UHF premier series ... UHF-R which is a load more money again :frown:
Got a link to these then? I assumed UHF-R as the word premier is in its marketing, but I don't think I have ever heard of a premiere series though. Maybe something specific to your side of the pond?
Seablade
seablade
Postby TSH-Tim » Tue Apr 12, 2011 8:44 pm
Umm how odd after a quick look around a cant find anything... apart from some pictures :?
Here is a picture of the system http://truesoundhire.co.uk/services/radio-microphone-hire
there quite old but i'll google this a little more and find the info for you.
TSH-Tim
Postby seablade » Tue Apr 12, 2011 9:12 pm
That is the Shure UHF series, the predecessor to the UHF-R series. And they were decent enough quality(Were at one time Shure's top of the line) that I would say that point 2 from above probably applies.
Seablade
seablade
Postby TSH-Tim » Tue Apr 12, 2011 9:22 pm
Hence why its not on the site anymore then.... you can see the signal drop-out when your hand is round the bottom. They have also dont it thou.
TSH-Tim
Postby shufflebeat » Wed Apr 13, 2011 1:47 am
Cheers, gang.
Plenty of food for thought there. I'll do my best to mention everything I've learnt from this post, while maintaining a nonchalont air of quiet confidence, of course.
In the interests of closure I will report back if and when he avails of the offer.
shufflebeat
