mixer to monitor hookup
Postby cavetti » Wed Apr 13, 2011 8:42 pm
i am new at sound setup and would like to know how do i use a PEavey xr8300 amp for a monitor amp using a pylepro powered pmx1208 mixing board as my main system. i have 1-aux on the pylepro and was thinking about using the peavey to drive 2 wedges through the main and monitor outs on the rear and using a wireless monitor system for the monitor out on the front panel.
cavetti
Re: mixer to monitor hookup
Postby PSR » Wed Apr 13, 2011 9:17 pm
An 8 channel splitter might be useful but you loose some sources because of the mismatch between the different number of inputs on your mixers.
e.g.
http://www.studiospares.com/splitter-combiners/art-s8-8-way-mic-splitter/invt/325480/
There's likely to be a work-around with most bands by feed the aux of your main mixer into a return on the peavy.
PSR
The PSR
