QSC PLX3602 problem
Re: QSC PLX3602 problem
Postby TSH-Tim » Tue May 10, 2011 11:00 am
Don't these amps have a HPF switch on the back of them ?
TSH-Tim
Postby Sheriton » Tue May 10, 2011 3:37 pm
Could be any number of different things. I assume you've tried the speaker with a different amp to check that the speaker is working correctly? And likewise tested that amp with a different speaker to confirm that the problem definitely lies with the amp? And double-checked you're not doing anything silly with the crossover or desk outputs? (We've all been there...)
If memory serves, the amp only has 30Hz and 50Hz HPF switches on the back so they wouldn't account for the problem you describe.
It would be quite unusual for an amp to fail with those symptoms - I'd certainly be looking elsewhere for the cause first.
Sheriton
There's nothing we can't face... Except for bunnies
Postby seablade » Tue May 10, 2011 3:55 pm
Nope, it should have both a HPF and LPF... see here...
http://www.qscaudio.com/images/hi_res/PLX2/PLX3602_rear_hi.jpg
And it sounds like the LPF is engaged and needs to be changed obviously if the OP is looking to use it with full range speakers.
Seablade
seablade
Postby TSH-Tim » Wed May 11, 2011 7:43 pm
TSH-Tim wrote:Don't these amps have a HPF switch on the back of them ?
Sorry i meant LPF ....
Also check where & what channels these settings are set to as am sure you can pick.
TSH-Tim
