recommendations sought for small PA..
Postby pax-eterna » Tue May 15, 2018 3:09 am
The JBL Eon 1 system (pair) I lease has ended the term so I wanted to look at an alternative new system.
Thinking I might go back to a more traditional setup as I am getting more club/pub gigs and I need a bit more “grunt”.
Thinking of two 12’s and a 12 sub, unless a 15 sub can be found that loads as easy as the 12, and can give a similar (not the same, but similar) results.
I play as a solo, with live keys and left hand bass using my own backing tracks, Mostly drums/guitars and vocals.
I was thinking 12’s as they will still give me some decent bottom when used alone at smaller venues. But I have read there are some 10’s that are not too shabby at the bottom end.
Budget is up to about $3500.
Perhaps I will give QSC’s a miss as I find them a bit shrill/piercing at higher volumes.
Needless to say, any system needs to be able to handle acoustic piano really well.
BUT, if there are systems comprising a pair of 10’s and a 12 sub then that’s even better purely from a transport/lugging p.o.v.!
pax-eterna
Re: recommendations sought for small PA..
Postby Sam Spoons » Tue May 15, 2018 9:23 am
Yamaha DXR10s are great, I bought a new EV ZXA1 12" sub last year but find myself leaving it at home in favour of the old school EV sBA 750 which sounds considerably better. The ZXA1 sounds good and can give plenty of level but just doesn't sound as good as the sBA750.
Postby pax-eterna » Tue May 15, 2018 4:44 pm
cool, thanks Sam....that give me a starting point. Had not thought of the EV at all. At 45kg it is a bit over the weight I'd prefer but the specs look ok... relatively low SPL though @128. Still, worth checking out.
pax-eterna
Postby pax-eterna » Tue May 15, 2018 5:07 pm
just checked out some EV gear - The ELX200 series look tasty - good specs too, and some pretty positive reviews. Nice weight.
Another one I saw is the Evolve 50 set - same sort of deal as the Eon 1, but absolutely eats the Eon in terms of power and sound projection, going on the specs. And I do like the ease of transport and setup of these type of systems.
I was only looking at a more "traditional" setup as I thought it would provide more "grunt" but that Evolve system does look good!
Thanks again for the EV cue...up til that I was really only looking at Yamaha and JBL (RCF's are too exxy for me!)
pax-eterna
Postby Sam Spoons » Tue May 15, 2018 5:49 pm
TBH if I was buying again and on a budget I'd buy the full rig from Yamaha's DXR range.
That old EV sub has platy of grunt despite it's slightly less than impressive max SPL. I rte ally do believe they don't make like that anymore :thumbup: They were very expensive back in the day, it was old when I bought it and it has had the speaker reckoned but only because the glue on the coil suspension had dried up and failed. Of course it helps that it's amp is a real 750 watts RMS unlike most modern kit (Yamaha included) that quote 'continuous' and 'peak' (or the even more meaningless 'dynamic' in the case of Yamaha) figures which, with no standard measurement system, they can massage to their hearts content. Even max SPL is only partially useful as they often don't quote distortion figures... :headbang:
Postby pax-eterna » Tue May 15, 2018 7:07 pm
haha, yeah manufacturers figures are tough to get a handle on these days!
Thing that appealed to me re the Evolve set was that the spl was about + 12 on the Eon system!
I will check the Yammie system too, although my initial research showed them to be a tad on the heavy side. Still worth a look though. Thanks
pax-eterna
Postby Sam Spoons » Wed May 16, 2018 12:48 am
The Evolve 50 is expensive compared to the DXR10s and well down on power. A single DXS15 and a couple of DXR10s will cost about the same as a single Evolve 50 but will go significantly louder. OTOH the Evolve rig is nice and light though and I don't think you are looking for max SPL as a main criteria. Time to go and have a listen?
Postby pax-eterna » Wed May 16, 2018 3:14 am
haha, yeah if I could...I'm 360 kilometers from the nearest store!! So need to rely a lot on reviews, forums like these and up to a point the guys in the shop.
FWIW, I decided on a pair of EV EKX200 12's and a pair of the matching 12's subs. After discussing it with the sales guys that system gave me the most options for the various venues I play at....he also suggested that using the 12's for a gig would work, just trim out the mids a bit.
I am used to these tower speakers giving a good sound level across the room and not just the front tables, where I have found traditional speakers, to get to the folks at the back are way too loud up front. But this guy assure me I could get the same result by simply droppig the mids a bit?? He reckoned that was the EQ secret behind the Bose L1 series.
pax-eterna
Postby pax-eterna » Wed May 16, 2018 3:15 am
pax-eterna wrote:haha, yeah if I could...I'm 360 kilometers from the nearest store!! So need to rely a lot on reviews, forums like these and up to a point the guys in the shop.
FWIW, I decided on a pair of EV ELX 200 12's and a pair of the matching 12's subs. After discussing it with the sales guys that system gave me the most options for the various venues I play at....he also suggested that using the 12's for a gig would work, just trim out the mids a bit.
pax-eterna
Postby Sam Spoons » Wed May 16, 2018 9:45 am
I'm not sure about 'dropping the mids a bit' myself, there's a lot more to it than that. The 'secret' behind the Bose is the dispersion/projection/or whatever, pattern of the speakers (as with any 'line array') much of which comes from their configuration.
In a perfect world, line array speakers would project a cylindrical wave front and, by extension, a point source speaker (a rough approximation of your new 12" boxes) would project a spherical wavefront. Meaning that the signal level from a perfect point source falls by 6dB every time the distance doubles and that from a perfect LA by only 3dB (inverse square law). In practice both types are far from perfect and, if you add that the effect is frequency dependent 'PS' boxes direct the HF in a narrow beam and the LF in a sphere and'LA' rigs direct the HF in a wider, flatter beam and fall off less with distance but their associated subs still project in a sphere.
On large Line Arrays, as seen at stadium gigs, cleaver tricks like frequency and level/volume shading address the issues (and the bigger a LA the lower the frequency at which the wavefront remains cylindrical). A little portable system only a couple of feet tall can only gain a certain amount of the effect and only at higher frequencies. So the Bose L1 will be better at directing sound where you want it than a QSCV K12 but will only get near the theoretical cylindrical wavefront at pretty high frequencies. I have used a Bose L1 and for acoustic music it was fantastic but not powerful enough for rock/pop etc in an average sized room.
If you're interested there's an excellent article here :-https://www.soundonsound.com/techniques/line-arrays-explained
Postby pax-eterna » Wed May 16, 2018 4:10 pm
Cool, thanks Sam!
pax-eterna
Postby DanR » Tue May 22, 2018 12:04 am
Hi
Not sure if you’re sorted with the PA but I can recommend RCF HD10a x2 and RCF 702as ii x2 for an ultra compact, light and great sounding PA.
The subs are so easy to transport that two can be used all the time which does away with the need for a speaker stand.
The system belongs to our bass player but I have two DXR10s for keys monitoring and
2x RCF HD12s and 2x RCF 905as subs as our main PA.
DanR
Postby pax-eterna » Fri May 25, 2018 7:53 am
Thanks Dan, and no not sorted - the ones I was looking at fell through (store sold them).
So that is a good suggestion :)
pax-eterna
Postby forumuser810278 » Thu Jun 14, 2018 6:49 pm
I’ve just taken delivery of a pair of dlr10s. Patching my Nord stage 88 straight through they are clean and loud. Slightly light on the bass but the FOH engineer should sort that. Plugging a mic in (a Beyer) very clean, slightly sibilant but for the money, great. (For a small intimate project venue for people with dementia. Acoustic grand piano means I could do with a bit of vocal reinforcement). Using my metric halo2882 I/o I tweaked the eq for a small multi mic pa (up to around 200) and found that they sound big and gorgeous with loads of headroom for a listening audience. And they fit in my car, and they weigh 10.5 kegs each!
So, if space/weight/cost is important, Yamaha 10”actives are a bit good.
But sweepable eq with the ability to dial q in makes a big difference.
Hope this helps.
forumuser810278
Postby Sam Spoons » Fri Jun 15, 2018 9:48 am
I guess you have DBR10s, not used them but I have a few DXR10s and they are, indeed, superb.
Postby Folderol » Fri Jun 15, 2018 3:00 pm
I keep wondering why anyone wants a diminutive Personal Assistant :?
OK, sorry, I'll get my coat.
Postby DanR » Fri Jun 15, 2018 3:51 pm
Sam Spoons wrote:I guess you have DBR10s
Yes, gonna say. Thought Yamaha had a new speaker out.
Another vote here for the DXR10s. Small enough for personal keys monitoring and plenty of power for full range small PA.
Use with a DXS12 sub and you’re golden.
Whilst the DXS12 is compact, it’s 33kg which is heavier than one of my RCF 905 15s (31kg).
Not by much though and still manageable.
DanR
