Yamaha o1v96i Question
Postby twotoedsloth » Sat Jul 28, 2018 5:45 pm
Hello, thanks for taking the time to read this.
I have a Yamaha o1v96i mixing console that I use for recording and PA. I use the aux 7+8 outputs to feed my power amp.
My question is: is there a way to insert a master eq after the aux send and before the output? This is to control potential feedback. Right now I just adjust each channel individually, which works, but is time consuming.
Please let me know your thoughts.
twotoedsloth
Re: Yamaha o1v96i Question
Postby Kwackman » Sat Jul 28, 2018 6:14 pm
Looks like it should be.
From the manual
"To set the EQ for Aux Out 1–8, press the DISPLAY ACCESS [EQ] button, then press the [F1] button to display the EQ | EQ Edit page, then use the [SEL] buttons to select Aux Out 1–8."
EDIT - this gets you the 4 band EQ, not sure about a Master EQ or what that is on the 01V. (I've a pre "i" version)
Kwackman
Postby Hugh Robjohns » Sat Jul 28, 2018 6:49 pm
twotoedsloth wrote:... is there a way to insert a master eq after the aux send and before the output?
Yes, just as Kwackman says. It's all described in page 37 in the manual :
https://usa.yamaha.com/files/download/o ... pdf#page29
You can insert a four-band EQ (and/or delay, dynamics processing etc) in any of the main stereo out, other output busses, and aux sends.
Postby twotoedsloth » Sat Jul 28, 2018 6:56 pm
Thank you both for your replies.
I will have to spend some more time with the manual. I still can't find where to set the EQ for my busses. The SEL button just selects the channel EQ, not the bus.
Sorry to be a bother,
Peter
twotoedsloth
Postby twotoedsloth » Sat Jul 28, 2018 7:02 pm
Found it!
The information they don't give you is that you need to select the master layer. Then you press EQ, F1, and whatever aux you want to EQ.
Thanks for pushing me in the right direction!
Very kind regards,
Peter
twotoedsloth
Postby andy nguyen » Thu Oct 24, 2019 4:38 am
twotoedsloth wrote:Thank you both for your replies.
Peter
To set EQ for Aux out (omni out 1-4) . Select Master layer - press channel 1 become Aux 1 - then press EQ. Now you will see aux1 EQ. To repeat for aux 2....
Good luck
andy nguyen
