Is it possible to do live sound engineering (FOH) using Ableton Live?
Postby savamill » Mon Aug 27, 2018 9:06 pm
Is Ableton Live okay for FOH?
savamill
Re: Is it possible to do live sound engineering (FOH) using Ableton Live?
Postby Argiletonne » Mon Aug 27, 2018 10:53 pm
If you can dream it, you can do it.
Argiletonne
Postby Dave Rowles » Thu Aug 30, 2018 12:32 am
Any DAW with a low latency interface can mix. The question is if it's the most effective way of doing it.
Try it and see what happens :)
Dave Rowles
http://www.manninmusic.com Bandcamp
Sound Engineer, Music Teacher, Isle of Man
Postby Wonks » Thu Aug 30, 2018 9:31 am
But the more plug-ins you use, the higher the latency.
Unless you've got an AI with lots of inputs and outputs and you need to use almost all of them, you'd really be better off with a standard hardware mixer for the immediacy of the controls and zero latency.
I'd suggest trying it out first in a rehearsal, rather than plunging straight into the deep end at a gig.
