Zoom Livetrak L-12 headphone outputs
PostPosted: Thu Aug 30, 2018 3:14 pm
by olibc
Hi,
I would like to know if someone tried to use active monitors on independent headphone outputs in the L-12.
Is this technically possible or recommended?
Do I need some DI (or something) between?
We are four members in a band. The main use of the L-12 would be for small rehearsal using active speakers for monitoring.
I am asking because the Livetrak L-20 has a button to switch headphone or line level for the independent headphone outputs.
Thanks a lot
Re: Zoom Livetrak L-12 headphone outputs
PostPosted: Mon Sep 03, 2018 4:45 pm
by molecular
I have, and it worked fine. I was using it with active HK Dart wedges. I can't remember how the levels were placed, but it definitely worked.
PostPosted: Tue Sep 04, 2018 10:00 am
by ore_terra
I missed this topic!
I've used them as well with monitors and they are usable like that.
PostPosted: Wed Sep 12, 2018 11:15 am
by olibc
Thanks for your answers.
I was told using active monitors in headphones output could produce a loss of quality or even distortion. So I wanted to know if people in "real" environment has notice some problems with the sound quality coming from active monitors or some other issues.
PostPosted: Tue Oct 16, 2018 8:20 am
by olibc
Hi,
I recently bought Zoom L-12. It is great and headphone outputs work ok with headphones. But I get very low volumes when connecting to an active monitor. I am using a jack (stereo) to XLR (male) cable as I usually did with my old mixer. If I level up volume almost to the max (of headphone output) it distorts and the volule of active monitor is still low.
What kind of cables are you using to make it work? Are you using a DI (or something similar)?
PostPosted: Sat Nov 10, 2018 7:19 pm
by ore_terra
I used to use jack cables to active speakers without issues.
PostPosted: Sat Nov 10, 2018 7:33 pm
A TRS headphone output is two separate unbalanced feeds, the XLR input to your powered speaker is expecting a single balanced signal. The TRS output from your old mixer will probably have been a single balanced output which is why it worked. They are not interchangeable and what you need to use your headphone output is a TRS to two TS jacks (and use two inputs on the powered monitor if it has them, TRS to 2 x RCA/phono jacks is another alternative or even TRS to mini TRS if the speaker has an iPod input) or a special stereo to mono summing lead with a TRS on one end and an XLR wired for unbalanced signal on the other.
