Midi over wifi.
Midi over wifi.
Postby Sam Spoons » Fri Sep 21, 2018 7:33 pm
I'm back to investigating the Berry X-Touch Compact as a cost effective mixing surface for my X32 Rack and XR12 mixers. The tech appears to have matured sufficiently that the X-TouchC will control the mixers adequately over midi but I would like to be wire free if possible. Is there an reasonable priced wireless midi system that works peer to peer without the need for a computer?
Re: Midi over wifi.
Postby BJG145 » Sat Sep 22, 2018 10:00 am
There don't seem to be many about. I use a CME WIDI. There's also the Panda midiBeam.
Re: Midi over wifi.
Postby Wonks » Sat Sep 22, 2018 10:34 am
I'd imagine you'd need full duplex MIDI, so the Panda looks to be out of the running for that application. And the WIDI-X8 is discontinued.
Re: Midi over wifi.
Postby Wonks » Sat Sep 22, 2018 10:43 am
The Kenton wireless MIDI system is input only on the transmitter.
This seems to be the only bi-directional MIDI transmitter I can find, but it's not cheap. https://www.midijet.com/index.php/index ... ory&path=7
Re: Midi over wifi.
Postby BJG145 » Sat Sep 22, 2018 11:12 am
Wonks wrote:I'd imagine you'd need full duplex MIDI, so the Panda looks to be out of the running for that application.
I wondered about that...could you do something with two of them...?
Re: Midi over wifi.
Postby Wonks » Sat Sep 22, 2018 11:37 am
You'd have to have a transmitter and receiver pair at either end. It's going to get rather expensive and cumbersome.
Re: Midi over wifi.
Postby Folderol » Sat Sep 22, 2018 11:40 am
Possible interference and latency could get 'interesting' too!
Yes. I am that Linux nut.
Re: Midi over wifi.
Postby Sam Spoons » Sat Sep 22, 2018 12:01 pm
Yes, looking like a non starter this one. Plan B is to dig out an old Android tablet and use the XTC to control Mixing Station on that. Sadly the iPad app doesn't accept midi control (yet....) and we all know the difficulties of using third party devices with anything from the fruit :headbang:
Basically I'm trying to avoid the easy fix and just use a laptop and the XTC.
Re: Midi over wifi.
Postby Wonks » Sat Sep 22, 2018 12:42 pm
Sam Spoons wrote:Basically I'm trying to avoid the easy fix and just use a laptop and the XTC.
It's a shame your forum name isn't Nigel.
Re: Midi over wifi.
Postby Sam Spoons » Sat Sep 22, 2018 12:45 pm
You may be right, but I'm totally failing to make plans.....
Re: Midi over wifi.
Postby Wonks » Sat Sep 22, 2018 12:55 pm
But I'm sure your senses are working overtime.
Re: Midi over wifi.
Postby Martin Walker » Sat Sep 22, 2018 3:34 pm
At least he's not turning Japanese :beamup:
Re: Midi over wifi.
Postby Wonks » Sat Sep 22, 2018 4:47 pm
Martin Walker wrote:At least he's not turning Japanese :beamup:
:?: ? Are you suffering from the vapours?
Re: Midi over wifi.
Postby Sam Spoons » Sat Sep 22, 2018 6:20 pm
No I'm ok, just had a message in a bottle, turns out it was a summons :blush:
Re: Midi over wifi.
Postby BJG145 » Sat Sep 22, 2018 10:24 pm
Dear God, can we get this thread back on topic? I'd like that.
Re: Midi over wifi.
Postby Sam Spoons » Sun Sep 23, 2018 10:32 am
Guilty as charged :tongue: But TBF the topic had run it's course.....
Re: Midi over wifi.
Postby where_theres_a_will_theres_a_way » Thu Dec 06, 2018 6:04 pm
This might be a late in the day question to ask but what sort of wireless range are you looking for?
The reason I ask is that Bluetooth modules are inexpensive and can do exactly what you are after. The range is dependent on which type of Bluetooth is used (more range usually costs more).
There is a small amount of latency with Bluetooth (as there is with whiffy) which may be a concern?
Re: Midi over wifi.
Postby BJG145 » Thu Dec 06, 2018 7:25 pm
BJG145 wrote:Dear God, can we get this thread back on topic? I'd like that.
(BTW this was nothing more than a desperate attempt to quote some more XTC titles.)
Re: Midi over wifi.
Postby Sam Spoons » Thu Dec 06, 2018 7:48 pm
You slipped that one past us BJG :D
I would probably need more range than BT can manage and, latency is already a minor issue (actually it's more the apps being a bit sluggish rather than wifi latency which is pretty good compared to BT)
Re: Midi over wifi.
Postby Wonks » Thu Dec 06, 2018 7:50 pm
I think you've hit the snail on the head there, Sam.
