Midi over wifi.
Re: Midi over wifi.
Postby where_theres_a_will_theres_a_way » Thu Dec 06, 2018 8:25 pm
I just did a quick search for BT 5 modules which have 800 feet range. I have a feeling that the latency is lower than WiFi but will look into it. With BT 5 you get more range when you lower the bandwidth so I have a feeling that 800 feet is just the start.
Modules available here.
https://www.fanstel.com/bt832-1-1/
They have some longer range devices to go > 1kM :bouncy:
That was just the first one I found.
Re: Midi over wifi.
Postby Richard Graham » Thu Dec 06, 2018 8:28 pm
+1 for Bluetooth. Korg’s MIDI over Bluetooth is great, very solid and low latency.
Richard Graham
"If a nail is bent, stop hitting it."
Re: Midi over wifi.
Postby where_theres_a_will_theres_a_way » Thu Dec 06, 2018 8:35 pm
Just found a reference, the BT 5 latency is <3ms which is about the same as Wifi (1-3ms) - depends on the number of users.
I was thinking of a hardware solution rather than something that runs on a laptop - MIDI connectors at each end, no wires in the middle.
I think I might make one just for fun :headbang:
Users browsing this forum: djangodeadman, Sam Spoons
