Midi over wifi.
Page 1 of 2
Midi over wifi.
PostPosted: Fri Sep 21, 2018 7:33 pm
I'm back to investigating the Berry X-Touch Compact as a cost effective mixing surface for my X32 Rack and XR12 mixers. The tech appears to have matured sufficiently that the X-TouchC will control the mixers adequately over midi but I would like to be wire free if possible. Is there an reasonable priced wireless midi system that works peer to peer without the need for a computer?
Re: Midi over wifi.
PostPosted: Sat Sep 22, 2018 10:00 am
by BJG145
There don't seem to be many about. I use a CME WIDI. There's also the Panda midiBeam.
Re: Midi over wifi.
PostPosted: Sat Sep 22, 2018 10:34 am
by Wonks
I'd imagine you'd need full duplex MIDI, so the Panda looks to be out of the running for that application. And the WIDI-X8 is discontinued.
Re: Midi over wifi.
PostPosted: Sat Sep 22, 2018 10:43 am
by Wonks
The Kenton wireless MIDI system is input only on the transmitter.
This seems to be the only bi-directional MIDI transmitter I can find, but it's not cheap. https://www.midijet.com/index.php/index ... ory&path=7
Re: Midi over wifi.
PostPosted: Sat Sep 22, 2018 11:12 am
by BJG145
Wonks wrote:I'd imagine you'd need full duplex MIDI, so the Panda looks to be out of the running for that application.
I wondered about that...could you do something with two of them...?
Re: Midi over wifi.
PostPosted: Sat Sep 22, 2018 11:37 am
by Wonks
You'd have to have a transmitter and receiver pair at either end. It's going to get rather expensive and cumbersome.
Re: Midi over wifi.
PostPosted: Sat Sep 22, 2018 11:40 am
by Folderol
Possible interference and latency could get 'interesting' too!
Re: Midi over wifi.
PostPosted: Sat Sep 22, 2018 12:01 pm
Yes, looking like a non starter this one. Plan B is to dig out an old Android tablet and use the XTC to control Mixing Station on that. Sadly the iPad app doesn't accept midi control (yet....) and we all know the difficulties of using third party devices with anything from the fruit :headbang:
Basically I'm trying to avoid the easy fix and just use a laptop and the XTC.
Re: Midi over wifi.
PostPosted: Sat Sep 22, 2018 12:42 pm
by Wonks
Sam Spoons wrote:Basically I'm trying to avoid the easy fix and just use a laptop and the XTC.
It's a shame your forum name isn't Nigel.
Re: Midi over wifi.
PostPosted: Sat Sep 22, 2018 12:45 pm
You may be right, but I'm totally failing to make plans.....
Re: Midi over wifi.
PostPosted: Sat Sep 22, 2018 12:55 pm
by Wonks
But I'm sure your senses are working overtime.
Re: Midi over wifi.
PostPosted: Sat Sep 22, 2018 3:34 pm
by Martin Walker
At least he's not turning Japanese :beamup:
Re: Midi over wifi.
PostPosted: Sat Sep 22, 2018 4:47 pm
by Wonks
Martin Walker wrote:At least he's not turning Japanese :beamup:
:?: ? Are you suffering from the vapours?
Re: Midi over wifi.
PostPosted: Sat Sep 22, 2018 6:20 pm
No I'm ok, just had a message in a bottle, turns out it was a summons :blush:
Re: Midi over wifi.
PostPosted: Sat Sep 22, 2018 10:24 pm
by BJG145
Dear God, can we get this thread back on topic? I'd like that.
