Anyone using a Behringer X32 with synths?
Page 1 of 6
PostPosted: Tue Oct 30, 2018 11:48 am
by The Elf
I'm considering moving from a pair of Zoom LiveTrak L-12 to a Behringer X32 (Compact or Producer) with optional X-Live card in order to capture live performance multi-tracks (while simultaneously acting as an audio interface for my own rig).
I was a bit dismayed to see that the main 16 inputs of the X32 are XLR mic inputs.
I really can't be bothered with 16 channels of DI, so I wonder if the mic inputs will be fine with synth outputs if I keep the mixer gains low.
Will this approach work?
Re: Anyone using a Behringer X32 with synths?
PostPosted: Tue Oct 30, 2018 11:56 am
by Dave B
I'd expect better of you Elf!
Yes, it should work fine, but I'd be looking at a bunch of 4 channel racked passive DI boxes and looms to the mixer to keep the stage neat and tidy and ensure you are balancing close to the source.
(just googled and you can get a palmer 8 channel for a couple of hundred - well worth the money)
Do it properly! :)
PostPosted: Tue Oct 30, 2018 12:02 pm
The Elf wrote:I was a bit dismayed to see that the main 16 inputs of the X32 are XLR mic inputs.
A lot of good mixers are built that way -- they aren't just mic inputs!
I reviewed the original X32 and ran a full set of technical measurements on it:
https://www.soundonsound.com/reviews/be ... -x32-media
In that report I stated: The mic preamps clip [with an input signal] at +23dBu, but with 0dB of gain dialled in an input of +21dBu registers as 0dBFS internally.
The published specs for the Rack version gives the same number for input overload, so I don't think you'll have any trouble with the outputs of your synths!
https://media.music-group.com/media/PLM ... K_M_EN.pdf
PostPosted: Tue Oct 30, 2018 12:18 pm
by Humble Bee
We went for the A&H Qu16 and would go for that again maybe the Qu24... TRS line ins or xlr mic ins... Built in recorder. Good price 2nd hand these days.
solid pice of kit!
Beh...
And this:
http://orchid-electronics.co.uk/passive_rack_DI.htm
PostPosted: Tue Oct 30, 2018 2:13 pm
by The Elf
Humble Bee wrote:We went for the A&H Qu16
From what I understand (and you wouldn't believe how difficult it is to get this kind of information!) the A&H won't act as an audio interface at the same time as recording internally, so no good for what I need.
PostPosted: Tue Oct 30, 2018 2:44 pm
by The Elf
Thanks guys, Everything I read seemed to suggest it would be fine, but it's good to hear it from those who understand all those numbers! It's a bit of a shame that the inputs aren't combis and there's no dedicated line/mic switch, but it is what it is.
This year's gigs are over, so I have time to upgrade before February. This is why I'm now looking to replace the Zooms. Like it or not (and I'll admit I can be sniffy about Behringer gear) it's one of the few mixers capable of what I need. Specifically I need a mixer that can act as an audio interface for my laptop at the same time as recording all of its separate inputs internally. Time and again I've checked out otherwise very capable gear that fails in this respect. Even the X32 itself can't do it without the addition of an X-Live card! It's a devil of a job trying to find out if mixers have this capability - nobody seems to know, including the manufacturer's technicians!
I need as simple and compact a solution as possible - the fewer boxes the better. Adding a DI box is not ideal.
The troubles I'm having with the Zooms are:
- Too few inputs. The new L-20 would seem like the ideal option, but I'm having other troubles related to the way the LiveTraks work that simply upgrading to more inputs isn't an ideal solution.
- The lack of moving faders is confusing the less technical band members. I've averted a couple of disasters related to this limitation, but I won't always manage to catch it. This is the biggest problem I'm having and the main reason for swapping.
- The resulting multi-track recordings aren't synced and getting them to sync properly back in my DAW is proving a bit of a chore. It can be done (and I was aware I'd have this issue from day one), but it isn't ideal.
- Lack of solo buttons can make setting up more onerous than it need be. I think this is fixed on the L-20, but...
For the above reasons I'll give the X32 a chance. The option to add personal monitor stations is a nice door to have open, though I won't be taking advantage of that in the short term.
PostPosted: Tue Oct 30, 2018 7:10 pm
by Bob Bickerton
Probably not at all what you’re looking for but the TASCAM Model 24 https://tascam.com/us/product/model_24/top has 16 line inputs and can record to SD card and is a USB interface. You’d have to enquire if it can do both at the same time and I’d imagine there’s other benefits of a digital mixer that you’d miss by using this one.
PostPosted: Tue Oct 30, 2018 8:24 pm
by The Elf
Nope, that Tascam can't do both at the same time. Very few can.
PostPosted: Tue Oct 30, 2018 8:31 pm
by Ramirez
I have a vague memory of offering to see if the Soundcraft UI24R will do what you want, but I don’t think I came round to it.
I could find the time tomorrow if it potentially fits the bill?
PostPosted: Tue Oct 30, 2018 9:52 pm
I have had an X32 Compact for 3½ years and it has lived up to (and usually exceeded) all my expectations. I don't gig much with it but it is my studio desk and audio interface. Like The Elf I was not a fan of Berry kit before the X32 but it really has been a game changer.
PostPosted: Tue Oct 30, 2018 10:03 pm
by Dan LB
I can confirm the X32 rack is certainly capable of handling signals from synths plugged directly into the XLR inputs.
I gigged for a year with one doing this and never had a problem.
The neatest way I found to achieve the jack to XLR conversion was with a short stagebox with jack sockets on the box and XLR tails.
Dan
PostPosted: Tue Oct 30, 2018 11:08 pm
by The Elf
Dan LB wrote:I can confirm the X32 rack is certainly capable of handling signals from synths plugged directly into the XLR inputs.
Great to hear first hand practical experience. Thanks,mate!
Dan LB wrote:The neatest way I found to achieve the jack to XLR conversion was with a short stagebox with jack sockets on the box and XLR tails.
That's a good point, and actually gives other advantages, since I could have a couple of 8-way boxes for extra flexibility.
PostPosted: Tue Oct 30, 2018 11:11 pm
by The Elf
Ramirez wrote:I have a vague memory of offering to see if the Soundcraft UI24R will do what you want, but I don’t think I came round to it.
Thanks, mate. It may help to have another option. I exhausted most options, or often I simply coudn't get a definitive answer.
PostPosted: Wed Oct 31, 2018 1:45 am
by Dan LB
Oh yeah, one other thing: be careful with the phantom power! :thumbup:
PostPosted: Wed Oct 31, 2018 6:18 am
by Humble Bee
