Acoustic stomp box
Page 1 of 2
Acoustic stomp box
PostPosted: Sun Dec 02, 2018 6:58 pm
by Nigel Austen
I'm looking to build or buy (if no more than £50 ) a stomp box for playing with a barn dance trio. Not looking for fancy footwork but just a simple main-beat bass drum sound operated by the foot , whilst playing an accordion .
Im particularly interested in what might be achieved using the EQ of my mixer (a Soundcraft Signature MTK ) . Ive seen various products and clips on youtube but they all seem to come out sounding like amplified floorboards - I'm looking for a softer bassier sound . I would be interested on thoughts about EQ on this e.g. if I bought or made something that really gives an amplified floorboard sound , could I get what Im looking for by taking the top and mid down and boosting the bass etc ? Or, do I really need to buy something that makes a deeper sound in the first place?
Grateful for any views . Cheers Nigel
PS I have heard all the accordion jokes ever told, so fight the urge if you think you have a new one!
Re: Acoustic stomp box
PostPosted: Sun Dec 02, 2018 7:33 pm
by Wonks
What's the PA you'll be playing it through? Have you got a sub? If not, you are unlikely to get any serious bass thump, regardless of any EQ.
PostPosted: Sun Dec 02, 2018 7:36 pm
by Wonks
One obvious option is to actually get a cheap small bass drum and pedal!
PostPosted: Sun Dec 02, 2018 7:52 pm
by Wonks
I've been trying to find out what Cormac Byrne (the percussionist) might have used when I saw him playing with Show of Hands last Thursday. Unfortunately I was sitting very near the front just below the stage line, so didn't have a great view, but he was certainly tapping something to get a kick drum sound. But it wasn't just a plugged-in unit as I could clearly see an AKG C418 clip-on mic hovering just over the unit (maybe for some extra 'click'). But that produced very bassy sound (too loud and bassy IMO as I thought it interfered with the vocals).
Here's a video which shows him doing something with his right foot, but I'm not sure just what it is. But with the PA reinforcement it was a lot bassier than in the video.
https://youtu.be/o3WBOCBX4vI
PostPosted: Mon Dec 03, 2018 9:58 am
by Sam Spoons
There was n old tech rider from a Bellowhead tour which included a spec for their stomp box :-
"The Stomp Box (our equivalent to a Bass Drum) is impossible to travel with, but essential for the concert and so we will have to build one upon arrival.
To make one for the concert we require the following items:-
Square Plywood Top : 7-Ply Marine plywood, 60cm x 60cm
Wooden Base Struts: 2 x L 60cm x W 7.5cm x H 7.5cm 2 x L 45cm x W 7.5cm x H 7.5cm
Sticky velcro tape
Hammer and wide-headed nails (To nail velcro)"
They used a boundary mic inside.
PostPosted: Mon Dec 03, 2018 10:47 am
by Sam Spoons
I've just remembered this device, I suspect it uses a magnetic pickup rather than a piezo device and sounds much better straight out of the box. Not available (easily, at least) in the UK so I built my own.
http://www.porchboard.com
PostPosted: Mon Dec 03, 2018 11:23 am
by blinddrew
Are you looking for a bass drum sound or something more 'woody'?
PostPosted: Mon Dec 03, 2018 1:05 pm
by Wonks
If you can find a cheap used drum machine that has trigger inputs, you could easily make a trigger pad from some wood and a cheap piezo disk, and trigger the kick sound on that.
PostPosted: Mon Dec 03, 2018 1:19 pm
by yaire
it's a little over 50 pounds but I think it will fit your bill:
The Ortega ANNAlog:
https://www.thomann.de/gb/ortega_annalog_stomp_box.htm
PostPosted: Mon Dec 03, 2018 1:38 pm
by CS70
One cannot but marvel at the resourcefulness of the gang here. :thumbup:
(added "build own kick box" to the future project list)
PostPosted: Mon Dec 03, 2018 2:02 pm
by Sam Spoons
Can post some design notes for the one I built later if anybodies interested?
PostPosted: Tue Dec 04, 2018 8:36 am
by ben howes
This might be your best bet.
https://www.roland.com/global/products/spd_one_kick/
Less faff to set up, and I'm positive you'll be able to find a suitable tone. Disguise it in a wooden surround if you feel like some wood work!
PostPosted: Tue Dec 04, 2018 10:01 am
by Wonks
However, you are unlikely to get one for £50, though it is a good solution. Unfortunately, the £50 budget does limit the possibilities somewhat.
PostPosted: Tue Dec 04, 2018 10:27 am
by MarkPAman
More by luck than judgement, a flight case lid with a cheap mic wrapped in foam under it did the job very well when somebody's more expensive device developed a nasty crackle. We auditioned about 4 different lids, and a 19" 8U one - 8mm ply? - did the job.
I've seen a regular kick pedal + cajon (possibly with snare wire removed) used to good effect. Think it may have had an extra bit of wood screwed to it to give the pedal something to clamp to.
Also seen chap on a tall stool just "stomping" on a cajon with his shoeless foot.
PostPosted: Thu Dec 13, 2018 9:44 pm
by Nigel Austen
Wow!
thanks for the usual SOS deluge of ideas ! Really appreciated . Looking into it , I don't think Ive actually heard an acoustic box with the sound I'm looking for - the one exception was when I saw Spiers and Boden play as a duo - they had a really great mellow kick drum sound - it was through a large Sub and I think the point made about getting an decent kick drum sound without a sub is bang on the nail. We don't use the with our line up but now thinking the best sound so far was from the Roland SPD 1 Kick but a bit over budget . I am going to look out for a used on a bit closer to budget and possibly try it with our usual speakers (Dynacord A115's) . If it doesnt sound good enough maybe invest in a cheapish sub that would be dedicated to the job .
Once again , contributions really appreciated and a lot to think about . Cheers Nigel
