difference with yamaha active
Postby gsc1ugs » Fri Dec 07, 2018 2:41 pm
what is the difference with yamaha active speakers DXR and DSR?
gsc1ugs
Re: difference with yamaha active
Postby Mike Stranks » Fri Dec 07, 2018 2:45 pm
Have you checked the on-line specifications to check-out the differences for yourself?
Your question is so broad that we could write hundreds of words and still not get to what you want to know.
So check the specifications and then come back with more specific questions please.
Postby gsc1ugs » Fri Dec 07, 2018 2:59 pm
I have :roll: not sure what i'm looking at, i think they are 134db and dxr 132db but that aint a lot go off
gsc1ugs
Postby Dave B » Fri Dec 07, 2018 3:05 pm
Edit : scrap what I wrote - I thought I read dxr vs dbr
Dave B
Postby Hugh Robjohns » Fri Dec 07, 2018 3:36 pm
gsc1ugs wrote:what is the difference with yamaha active speakers DXR and DSR?
Yamaha's DSR speakers came first. The DXR range was developed later as a similar but lower-cost range with slightly less impressive specs and materials, but also having smaller models.
So the main differences are that the DXR range models have slightly less power than their DSR equivalents, and correspondingly less SPL, with less robust materials lower weight and less extended and less flat frequency responses.
Basically, they are cheaper, with all that that entails. (But that's not to say they aren't good value for money...)
Postby Wonks » Fri Dec 07, 2018 3:59 pm
Postby gsc1ugs » Fri Dec 07, 2018 6:02 pm
Brilliant advice thank you
gsc1ugs
