t.bone IEM-75 with two receivers
Postby rokyronnie » Mon Feb 11, 2019 3:32 pm
Hi,
Does anybody know if the t.bone IEM-75 is capable of running with two IEM-75R receivers at the same time? even though they would have the same monitor-mix.
Thanks!
rokyronnie
Re: t.bone IEM-75 with two receivers
Postby Mike Stranks » Mon Feb 11, 2019 3:58 pm
Yes; that will be fine as long as you realise that it will be an identical mix going to both of the receivers.
Obviously all of the separate pieces of kit have to be tuned to the same frequency.
Also be aware that if you have any radio mics there's the possibility of frequency clashes. Best to check that mics and IEMs can be tuned to different frequencies with sufficient gap between them before ordering the IEMs.
HTH
Postby Hugh Robjohns » Mon Feb 11, 2019 4:08 pm
rokyronnie wrote:Does anybody know if the t.bone IEM-75 is capable of running with two IEM-75R receivers at the same time?
Yes. It works much like broadcast radio. You can have as many receivers picking up the IEM base-station's transmission as you like... but they will all get exactly the same signal, of course.
Postby rokyronnie » Mon Feb 11, 2019 10:27 pm
Thank you guys!
rokyronnie
