MixWizard WZ4 16:2 need a multicore
Postby manleyelop » Tue Feb 19, 2019 9:03 pm
i have the MixWizard WZ4 16:2
Can anyone recommend a good quality 30 meter 16 in 6 return (approx ) multicore ?
manleyelop
Re: MixWizard WZ4 16:2 need a multicore
Postby Janneman » Tue Feb 19, 2019 9:07 pm
What is your budget?
Janneman
Kind regards,   Jan van Duren
Postby manleyelop » Tue Feb 19, 2019 9:16 pm
Janneman wrote:What is your budget?
Lets say £500 max i've had a 30 meter piranha multicore for yrs never let me down but it's only 8 in 4 return unless i could modify it somehow i need something to allow more stage monitors & sends ive got 2x desks A&H 8:2 & A&H 16:2
manleyelop
Postby James Perrett » Tue Feb 19, 2019 9:52 pm
Do you really need 6 returns? 16 inputs with 4 returns is a common configuration whereas you may need to go up to 24 inputs for 8 returns. I've used a couple of the ones at
https://www.rapcohorizon.com/product/28 ... urn-snakes
which seem reasonably solid although I'm not using them for regular live gigs. I also paid much less than the price on that page (although it was a while ago).
Postby MarkPAman » Tue Feb 19, 2019 10:07 pm
How about a second 8+4? Or maybe a 12+4 which are quite common?
You get the option to use one or both depending on the gig, and the useful flexibility to put them in different places on stage - front and back, or left and right.
MarkPAman
Postby manleyelop » Tue Feb 19, 2019 10:12 pm
James Perrett wrote:Do you really need 6 returns?
i get asked for 3x independent stage monitors now & again so yes 2 returns are taken by the p.a power amps which leaves me 2 i need one extra return atleast unless im missing something if so im all ears
manleyelop
Postby Mike Stranks » Tue Feb 19, 2019 10:19 pm
I would frequently be running 6 lines back to the stage when I was in 'full-blown' mode - 2 for FoH plus 4 monitor mixes.
I was using a 16:4 and just used some XLR gender-changes to give me an additional 2 returns, thus making the snake into a 14:6. :)
Postby manleyelop » Tue Feb 19, 2019 10:27 pm
Mike Stranks wrote:I would frequently be running 6 lines back to the stage when I was in 'full-blown' mode - 2 for FoH plus 4 monitor mixes.
Hi Mike yes i was wondering if i could modify the 8/4 somehow making it an 8/5 by adding a cable onto it instead of spending more cash than i need to gaffa tape gets messy though
manleyelop
Postby manleyelop » Tue Feb 19, 2019 10:31 pm
MarkPAman wrote:How about a second 8+4? Or maybe a 12+4 which are quite common?
Hmm now that could be a good idea i constantly have to modify depending on the gig :bouncy:
manleyelop
Postby Hugh Robjohns » Tue Feb 19, 2019 10:39 pm
Yes, I'd also suggest a second 8-4 multi. Cheaper, lighter, more flexibility.
Postby manleyelop » Tue Feb 19, 2019 10:40 pm
Hugh Robjohns wrote:Yes, I'd also suggest a second 8-4 multi. Cheaper, lighter, more flexibility.
yes great idea now why didn't i think of that :headbang:
manleyelop
