Solo Artist - Backing Tracks
Postby JonaWilder » Tue Feb 19, 2019 9:16 pm
Hey everyone,
I'm a solo artist and have a couple questions regarding live backing tracks.
I'm going to be playing shows with me singing / playing guitar and a laptop playing backing drum tracks that sound like a drum machine. I'm going to play the tracks from iTunes and am connecting my laptop to the venue PA via an interface.
My question is: Is playing a pre-mixed drum track via laptop - interface - PA a viable option or would it be better to have an app / program with each individual drum track (kick, snare, etc).
Couple things I know will come up in the answers:
I am aware of Abelton, but it is also 800 bucks
I am also aware of physical drum machines, but most are rather pricey and aren't able to have pre-set songs or a start/stop controller
I know getting an actual drummer would be best, but hey sometimes there just ain't anyone around
Thanks, looking forward to getting your feedback!
JonaWilder
Re: Solo Artist - Backing Tracks
Postby MarkPAman » Tue Feb 19, 2019 9:26 pm
What’s your laptop?
MarkPAman
Postby Mike Stranks » Tue Feb 19, 2019 10:21 pm
Speaking personally, in that scenario I'd much rather have a pre-mixed kit - ie only two channels coming down the line - rather than be expected to mix a drum kit against a solo singing guitarist.
Postby artzmusic » Tue Feb 19, 2019 10:58 pm
For simplicity, I prefer mp3 of my backing tracks played with a tablet. As a solo player, all I need to adjust is the volume and I'm good to go for the night.
artzmusic
Postby Bob Bickerton » Wed Feb 20, 2019 2:45 am
Agreed the best solution is a tablet (iPad in my case) with a Bluetooth pedal playing back a pre-mixed stereo track. Lots of good apps to support this.
Bob Bickerton
http://www.bickerton.co.nz
Postby Sam Spoons » Wed Feb 20, 2019 9:32 am
A Boss RC-30/300 could also do the job and be completely foot operated. I'd go for the RC-30, you'd need an additional dual footswitch to switch tracks but it is a robust and relatively cheap solution (£160 in the UK but, apparently $300 t'other side of the pond :o ).
Postby JonaWilder » Wed Feb 20, 2019 4:25 pm
Thanks everyone! Sounds like my Macbook running the backing track through iTunes into an interface into the PA is the way to go. Definitely will test the mix on my own PA speakers first though to get a grip on how it sounds.
JonaWilder
Postby Janneman » Wed Feb 20, 2019 5:35 pm
Try mainstage!
Janneman
Kind regards,   Jan van Duren
Postby MarkPAman » Thu Feb 21, 2019 5:35 pm
OK, if you have a MacBook, then download QLab. Free!
It is designed for just this type of job.
Without a licence, you can:
Playback any stereo track,
Adjust its speed, and/or pitch,
Adjust volumes and add fades,
Adjust start and end points,
Have it stop at the end, or continue to the next track (after a set amount of time),
Have a trac start while the previous on’s still fading out,
Change the order just by dragging stuff around,
Assign hot keys to the qwerty, or to a midi device,
Jump to anywhere in you set with one click,
See elapsde or remaining time.
Save as many versions of your show as you want.
Have it copy all the media you’ve used into one folder
....and probably some other useful things I’ve forgotten......
Also
Playback video and, with a sutable interface, control a few lights!
Got to be better than iTunes :D
https://figure53.com/qlab/
MarkPAman
