Synth Cases for Live Setup and Transportation
Re: Synth Cases for Live Setup and Transportation
Postby MarkyC » Wed Jul 17, 2019 9:59 am
Thanks DanR,
Initially, I have gone for and aluminium board with an aluminium frame.
I'll rig it up and then see if I trust it (It seemed stronger and lighter than wood, but not sure about resilience)
The perspex idea is interesting alos, and not that expensive.
Interested in Flightcasewarehouse - have asked them for a quote as I'm suspecting the aluminium board may not be robust.
So thanks for the insight!
MarkyC!
MarkyC
Postby DanR » Wed Jul 17, 2019 11:45 am
MarkyC wrote:
My setup would be (Bass station 2, Peak, TR8, Key-Largo to mix + orico usb powered hub to sync everything + plugs). On my table, after connecting everything, the foot print comes to about 90cmW x 70cmD x 9 cm high.
Just looking back at at this, do you want the whole lot on a board?
That’s gonna be big.
I’d certainly keep the Novation Peak seperate and maybe the Bass Station 2 aswell.
The other three items would be prewired on the board so all you need to do is
plug in one mains and the usb/audio leads.
DanR
