Vocal microphone question
Re: Vocal microphone question
Postby awjoe » Mon Jul 22, 2019 5:44 am
Bob Bickerton wrote:
When I first saw the OM7s response, I thought it couldn't possibly be true...
Whilst I'm still not sure the OM7 specs are indeed true - they are born out on stage.
Have you ever been tempted to use one in the studio?
awjoe
Music production is like finding a good hair dresser
Postby ef37a » Mon Jul 22, 2019 7:33 am
Bob Bickerton wrote:Sorry to labour the point - but have you actually compared the polar patterns of the two mics? If not, please have a look.
http://cdn.shure.com/specification_sheet/upload/82/sm58-specification-sheet-english.pdf
https://audixusa.com/docs_12/support_pdf/OM7_V2_0615.pdf
Unless I'm reading them wrong here are some comparisons (2kHz up range):
OM7 @ 30º off axis = -9dB | SM58 @ 30º off axis = 0dB
OM7 @ 60º off axis = -18dB | SM58 @ 60º off axis = -5dB
OM7 @ 90º off axis = -21dB | SM58 @ 90º off axis = -5 to -10dB
and so on........
And, by the way, the argument about attenuating an SM58 to match doesn't bear up - you compare the microphones with the gain set appropriately for the source and under those circumstances the OM7 provides more gain before feedback.
Anyone would think I'm an OM7 fanboy - actually I'm a real world fact fanboy ;)
Not arguing Bob, don't have one nor the place to try it. I was just looking for the "Amazing New Principle" that gave the OM7 its feedback immunity and found there isn't one. It is a very low sensitivity mic that requires very close use* and necessitates the singer gives it some. The tighter polar pattern helps as well.
Not knocking the OM7! Super mic I am sure, just works by principles known for a century.
Attenuating a "lesser" microphone would then require very close working. Even a 58 could overload some mic pres in such a situation with some singers? (Tom Jones had a bit of a reputation as a mic masher!) I think my statement "mics are but one factor in feedback control" still stands? If the singer does not work it correctly, even the OM7 will squeal!
*The old noise cancelling Reslo used in F1 pits worked on a similar principle in that it required a very close technique and had a guard ring so as to get the mouth in the dead right position (yes, I know it also exploited the proximity effect and EQ'ed the pips out of the signal!)
Postby ef37a » Mon Jul 22, 2019 9:04 am
AlecSp wrote:
ef37a wrote:One wonders how an SM58 might perform with a -6dB slug in the cable?
Exactly the same, other than the fact you'll need to add back the 6dB elsewhere in the signal path. After all, gain is gain, no more and no less, wherever it is in the signal path.
Except that if you left the gain as was the singer has to work harder. One of the abiding principles of good feedback control (or indeed low noise amplification) is...Get the biggest signal you can. In this case the acoustic output of the gob.
Postby Wonks » Mon Jul 22, 2019 9:33 am
True, an increase in the signal/background noise ratio is always welcome and benefits gain before feedback. However a high output mic and a low output mic with the same polar pattern, if the mixing desk gain is set up so that both signal levels going through the desk are the same , then there will be the same gain before feedback level for both mics.
A higher output mic signal will result in less mixer gain needed, which can result in a higher signal/electrical noise ratio, but doesn't affect feedback resistance as the overall system gain is exactly the same. 20dB (mic) + 60dB (preamp gain) = 80dB, the same as if if were 25dB +55dB (figures for example purposes only).
The only way to really increase gain before feedback is to have a much tighter polar pattern. Ideally you want a mic where only the sound in front of the mic is captured, but this has practical and sonic limitations. So you end up with a mic like the OM7 which has a very tight, very directional, pickup pattern with a lot of rejection to the sides and rear. But the result is a mic whose output falls off very rapidly if you move your mouth to the side by a cm or so. So it needs to be kept right up against the mouth just to make sure the vocals don't sound like Norman Collier. https://youtu.be/AYpQyJ_bTiw
Postby shufflebeat » Mon Jul 22, 2019 9:38 am
ef37a wrote:...I was just looking for the "Amazing New Principle" that gave the OM7 its feedback immunity and found there isn't one. It is a very low sensitivity mic that requires very close use* and necessitates the singer gives it some. The tighter polar pattern helps as well.
All kind of correct (apart from your artistic use of question marks, but my daughter tells me I must own my own pedantry and not judge).
As a regular user I concur with Bob B's observations and conclusions. I don't think Bob is suggesting there is any magic ingredient but rather that Audix have prioritised GBF in response to the modern stage environment and have manipulated the existing variables very successfully.
As mentioned before I like to turn the OM-7 input gain up and sing gently. If you are suggesting that this would compromise the GBF properties, it doesn't (in comparison with '58, e935, etc.).
It also sounds good.
[edit]
I would qualify the suggestion that a singer needs to be in direct contact with the OM-7 to be effective, that's an exaggeration. The range is dramatically reduced but normal rules regarding movement on and off the mic still apply.
In real life, if you've probably chosen the OM-7 it's because the stage is loud and in those cases folks are belting into the mic and performance is less nuanced.
shufflebeat
Postby Bob Bickerton » Mon Jul 22, 2019 9:42 am
awjoe wrote:Have you ever been tempted to use one in the studio?
Not in the studio as I have better mics available, but I'd consider it in a live band recording situation where I wanted to reduce spill on a vocalist.
Bob Bickerton
http://www.bickerton.co.nz
Postby Bob Bickerton » Mon Jul 22, 2019 9:57 am
ef37a wrote:Not arguing Bob, don't have one nor the place to try it.
Oh yes you are ! ;)
ef37a wrote:I was just looking for the "Amazing New Principle" that gave the OM7 its feedback immunity and found there isn't one.
Of course there's no " Amazing New Principle" - but Audix have engineered a microphone which has managed to attenuate pick-up from the sides and rear like no other microphone that I'm aware of, as evidenced in their published data and my actual experience. Did you analyse the polar responses?
I'm really surprised you're holding out on this one Dave, given you haven't tried one. Round here, we like to give good advice when it's asked for, don't we?
When I'm asked what stage vocal microphone are best for feedback rejection - I'll answer the OM7 based on my analysis of the data provided and practical experience. BUT as noted, it's a compromise and requires absolute 'nasal hair trapped in the grill' technique.
Ho hum........
Bob Bickerton
Postby Hugh Robjohns » Mon Jul 22, 2019 10:09 am
ef37a wrote:I was just looking for the "Amazing New Principle" that gave the OM7 its feedback immunity and found there isn't one. It is a very low sensitivity mic that requires very close use* and necessitates the singer gives it some. The tighter polar pattern helps as well.
I think you have that the wrong way around Dave. It's the very tight polar pattern that gives it the feedback immunity, and the lower sensitivity helps as well...
Any mic can be operated with a low sensitivity... But what makes a real difference is how well the mic rejects unwanted sound from directions other than the vocalist -- and that's where the very tight pattern of the OM7 really makes such a big difference.
Of course, but even then if there are high levels of foldback/spill on stage, it would still start to feedback before the OM7 because it is much more sensitive to sounds from the sides...
Obviously... but they'd have to try a lot harder than with an SM58... and that's what matters! :-)
Postby Tim Gillett » Mon Jul 22, 2019 11:37 am
Is the the OM7's attenuation of side sound because it's hypercardioid? Isnt the SM58 less able to do that because it's cardioid? If so, shouldnt we compare apples with apples?
Tim Gillett
Postby Hugh Robjohns » Mon Jul 22, 2019 12:08 pm
Tim Gillett wrote:Is the the OM7's attenuation of side sound because it's hypercardioid?
Of course.
Of course.
We're comparing popular stage vocal mics aren't we?
The OM7 is better at feedback rejection than the SM58 (and most other stage vocal mics).
It might be interesting to compare the OM7 with other nominally hyper-cardioid stage mics in a practical situation. If you (or anyone else) feel so inclined I'd love to see the results.
Postby ef37a » Mon Jul 22, 2019 12:25 pm
Of course.
Of course.
Me too!
Postby Sam Spoons » Mon Jul 22, 2019 3:27 pm
Peter H wrote:If I were the OP, I'd get an SM58 (or similar) AND an E945 (or similar?) and compare. There are so many idiosyncratic factors involved in live gigs, and that's before even considering the vocal channel/EQ etc. and the speakers.
The OP already uses an SM58 IIRC.
MOF wrote:
Looking at the OP's (lip-synched) showreel he appears to slightly cup the mic basket which, as we know, is almost guaranteed to make a 58 feed back. Am I right in thinking that the effect would be even worse with a super/hyper-Cardioid?
Doing this makes the mic’ go into an Omni’ pickup pattern so I don’t think it will be any worse with a hyper-cardioid mic’ but clearly no good at feedback rejection.
Makes sense.
Postby Bob Bickerton » Tue Jul 23, 2019 12:16 pm
Hugh Robjohns wrote:It might be interesting to compare the OM7 with other nominally hyper-cardioid stage mics in a practical situation. If you (or anyone else) feel so inclined I'd love to see the results.
We ran tests a few years back to replicate a fairly typical stage scenario where a lead vocalist in a rock band would be requiring high gain from a single monitor. I don’t think we repeated the test with dual monitors. This was done in a 400 seat theatre with sensible positioning of FOH speakers, so potential feedback was only from the monitor.
From memory the hypercardioid mics we tested were:
Beta58
RE510
KMS105
E845
M69
M88
Possibly ND967
OM7
I wouldn’t describe it as a scientific test! Channel and monitor EQ were flat. For each mic an optimum gain was set to deliver the same level for the vocalist and then the gain in monitors was increased until feedback occurred and compared. The OM7 won out by a long shot and this has since been proven ‘in the field’.
I’m not saying the OM7 is the best mic, I tend to grab an M69, M201 or KMS105 first up (dependent on voice and genre), but it is the most feedback resistant I’ve come across.
Bob Bickerton
Postby Hugh Robjohns » Tue Jul 23, 2019 12:46 pm
Thanks Bob. Interesting stuff.
Postby Tim Gillett » Tue Jul 23, 2019 1:03 pm
I looked up those mic specs. As best I could find, here are the nominal polar patterns, H being hypercardioid and S supercardioid. So not really a test of hypercardioids.
And of course it depends on the angle from the mic's axis at which the monitor is placed. At some angles you would expect the supercardioids generally to have better feedback resistance, and at others, the hypercardioids better. And of course depending on the frequency...
Beta58 S
RE510 S
KMS105 S
E845 S
M69 H
M88 H
Possibly ND967 S
OM7 H
Tim Gillett
