Replacement for Bose 802
Page 1 of 4
PostPosted: Sun Jul 21, 2019 10:47 am
by NickBellows
We have been using Bose 802s (series 2) in our PA for a very long time now.
We have the module of course and are driving them with an Inuke 3000 which works fine for us.
However, they are fairly old now and even though they are not huge, they are quite heavy to mount on our stands.
We would really like to replace them with something that performs as well (or better) but is far more compact too. (I don't have a lot of boot space and something easier to handle would be really helpful).
Any suggestions?
Nick
Re: Replacement for Bose 802
PostPosted: Sun Jul 21, 2019 11:17 am
A couple of Yamaha DXR10s would be my suggestion as a good compromise between size/weight/price and performance.
PostPosted: Sun Jul 21, 2019 11:19 am
by Mike Stranks
Bose 802: excellent in their day, but now surpassed by modern gear.
A few answers will help us give informed answers:
- Style of music played/genre?
- What's the line-up and does it all go through the sound system?
- Size of typical venue?
- Budget?
There's lots of cracking kit out there so we'll definitely be able to recommend something - almost certainly from personal experience.
As you know, these days most of us prefer self-powered speakers. Are you happy to go with that?
PostPosted: Sun Jul 21, 2019 11:25 am
by Wonks
DXR10s would be my suggestion as well. There's now a Mk II version, but they are only a small improvement (1dB louder) than the originals, so used or end-of-line Mk 1s are well worth looking at and they will be significantly louder than the Bose rig. Great sounding speakers and nice and compact. One reason I chose them over the 12" versions.
PostPosted: Sun Jul 21, 2019 11:45 am
by NickBellows
No problem going with powered speakers.
We are a Ceilidh band. Amplified acoustic - fiddle, squeezebox, guitar(plus an Electric upright bass. All through the system.
Usual venue - wedding hotel / village hall, but occasionally a large conference centre (our inuke 3k + Bose has worked fine for the largest venue we play at).
DXR10s look good and it looks like I should get at least £250 from selling 802s + controller + Inuke so about £550 to find (can't see any second hand at the moment).
Other suggestions to compare appreciated too particularly anything compact.
Cheers
Nick
PostPosted: Sun Jul 21, 2019 12:10 pm
by Peter H
If going for active speakers (I have also changed over completely from passive, and sounds like we have similar bands/venues), in my experience the Yamaha (DXR series, or lighter, cheaper DBR series) or QSC K series, are brilliant, and for me it's mainly a matter of weight against loudness/lower frequency handling (cost as well of course). It's slightly different if the electric bass is also going through the system - that tends to take a lot of speaker!
PostPosted: Sun Jul 21, 2019 12:49 pm
by DanR
Another vote for Yamaha DXR10.
As mentioned, it would be useful to know if there’s any backline and monitoring. If the bass player has a combo then 10’s should do fine.
A nudge up in sound quality would be RCF HD10 Mk iv’s or their Art 710.
If funds allow, add an RCF 702 as ii sub for a great sounding, compact and flexible PA.
Use the tops for most gigs, then add sub for larger ones.
PostPosted: Sun Jul 21, 2019 1:48 pm
by NickBellows
Interesting for comments on bass.
We have always put him through our system and it seems to have worked fine (nothing to compare it with I suppose).
We have 4 TC Helicons we use for monitoring - absolutely love them.
More than we can afford to up the bass at the moment - not even sure how it works with the system, this will sound very naive, but where would the sub take its signal from?
PostPosted: Sun Jul 21, 2019 1:55 pm
by Wonks
I assume you use the PA in 'dual mono' mode i.e. with all channels panned centrally?
Then you'd just take an output feed from one of the active speakers into the active sub. Or you can do it the other way round (if you are using stereo - say for interval music) and take the mixer L+R outputs into the sub and take the L+R output feeds from the sub to the two tops.
The first method saves on a cable, but depends on the tops having their own HPF and the sub its own LPF (which the Yamaha system components do). If not, then the sub will have HPF outputs for the tops, so always use the second method.
PostPosted: Sun Jul 21, 2019 2:00 pm
by DanR
NickBellows wrote:where would the sub take its signal from?
From a mixer usually. Does the band have one?
Full range signal into sub input then the High Pass out to the two top speakers. The sub splits the signal using an onboard crossover.
PostPosted: Sun Jul 21, 2019 2:02 pm
by Wonks
DanR wrote:
NickBellows wrote:Full range signal into sub input then the High Pass out to the two top speakers. The sub splits the signal using an onboard crossover.
Not on all systems. A lot, but not all. The Yamaha range have low pass filters in the subs and HPF in the tops, but their chaining output signals are full range.
PostPosted: Sun Jul 21, 2019 2:07 pm
by NickBellows
We use a soundcraft spirit E8
It looks like my query about signal is answered.
It looks like the Yamahas are what we need.
Maybe get a sub for the bass if we are flush one day.
PostPosted: Sun Jul 21, 2019 2:08 pm
by Mike Stranks
In the light of what you've said Nick I'll also put a vote in for the DXRs. They can give a good account of bass as long as you're not expecting hyped trouser-flapping, chest-thumping stuff.
I used to have some; classy kit.
PostPosted: Sun Jul 21, 2019 2:30 pm
by Peter H
Can I hesitantly put a possible spanner in here - in my experience it is a big deal for choices of gear if the bass player does, or does not, go through the main PA. In jazz-type small/medium gigs, it's so much easier if the bass goes alone, and for example you may even be OK with yamaha DBR10s, DXR8, or QSC K8. (I assume the drums are not miked)
PostPosted: Sun Jul 21, 2019 2:32 pm
by DanR
Yes, forgot that. QSC K series too have full range out from subs. HPF is in the K tops.
