Keyboardist volume advice
Re: Keyboardist volume advice
Postby Peter H » Sat Jul 27, 2019 9:33 am
Excellent thread! In particular, Dave and Eddy have made really great points. I agree completely about the difficulty of live keyboard self-monitoring on gigs with heavy guitars - organ-like sounds so completely different from the transients produced by guitar strings! I try always to use my own monitor even if big PA system provided, then heavily tweak my eq so I can hear myself properly even if my monitor sound is unrealistic, or get to know the engineer for similar (i.e. it’s not just about volume). I would be wary of any solution not fully involving the keyboard player (volume 105 will soon become 127 again:)
Peter H
Peter Houtman
Postby Dave B » Sat Jul 27, 2019 10:46 am
ReedySteadyGo wrote:And record the session so he can hear how the volume of the keys is changing.
Good suggestion with one qualification : record the sound in the room, don't take a split to a separate recorder from a desk. You need to understand how all the various sounds fit together in an overall mix and anything taken direct from the desk will confuse things more. Put a couple of mics / small recorder at one end of your rehearsal space, ideally as far back as practical. It will capture the sound that the audience hears - and that's what we are aiming to get right.
Dave B
Postby Mike Stranks » Sat Jul 27, 2019 11:18 am
Mike Stranks
Postby Janneman » Sat Jul 27, 2019 1:08 pm
Set the keyboard on a 1/2 the output, put some gaffa tape over the slider, split the output signal to FoH and a smallmixer. So the keyboard can use the mixer to control his own volume and without upsetting the FOH guy,
Janneman
Kind regards,   Jan van Duren
Postby Wonks » Sat Jul 27, 2019 1:24 pm
On the few occasions when i was mixing, Dave B's keyboard levels were always there or thereabouts, really only needing pushing up slightly for solos. The only time I did anything major was in Van Halens' 'Jump', where I really upped the bass-end and the overall keyboard level considerably.
