Quick mp3 question
Re: Quick mp3 question
Postby Mike Stranks » Tue Aug 06, 2019 8:58 am
Tim Gillett wrote:I occasionally do the same Mike, when I need to send demos to a customer or friend via email where here there's a 10 Mb size limit. It can be a fun challenge to pull every trick before encoding to make it sound as if it's not a low bitrate mp3. I think it was Mandy Parnell who said something like "that's real mastering", or at least what mastering used to be - making a lower fidelity delivery format still sound good.
Not meaning to be patronising Tim, but you do know there are apps available where you can send fairly chunky data sets for free? (I don't mean Dropbox, Googeldrive et al...)
I've used several, but of late I've settled on WeSendIt https://www.wesendit.com/ as it's reliable, simple to use and, most importantly, easy for the recipients to access the sent files.
Just a thought...
Mike Stranks
Postby Tim Gillett » Tue Aug 06, 2019 9:13 am
Not at all, Mike, thanks for the tip.
Tim Gillett
Postby CS70 » Tue Aug 06, 2019 10:03 am
Just a thought...
As an incidental - it's funny that there are some unexpected cases where actually that doesn't work, for surprising reasons.
A couple years ago I did some video work for a middle-eastern singer, who wanted to send the finished product back to radio services in his home country. The video came out well and very high quality - but It turned out that the main communication system in his country is some sort of 3G or even Edge mobile network, so the video size had to be incredibly small to allow the majority of people to watch it.
I spent more time working the the coloring so that I could get it to the required size without it looking like lego blocks, than actually filming and mounting it.
We're lucky in our little worlds :)
Postby blinddrew » Tue Aug 06, 2019 12:49 pm
CS70 wrote:I spent more time working the the coloring so that I could get it to the required size without it looking like lego blocks, than actually filming and mounting it.
Ugh. Tell me about it, restricted bandwidth is a major bane of my working life at the moment. You spend ages (well, a decent amount of time) getting a nice, clear, good sounding video, and then you have to compress the snot out of it to get it round the network and the colours go funny, the sound gets ugly, and everyone looks like they've been trying Trump's make-up cabinet. :(
Postby CS70 » Tue Aug 06, 2019 1:26 pm
Make it black and white and it'll compress in a breeze! :D
Postby Mike Stranks » Tue Aug 06, 2019 2:47 pm
With videos why not just put it on YouTube as 'unlisted'?
That's what I do. Only those with the specific link can access it and when everyone who needs to has seen it you just delete it.
Job's a good 'un!
Mike Stranks
Postby blinddrew » Tue Aug 06, 2019 4:01 pm
Mike Stranks wrote:With videos why not just put it on YouTube as 'unlisted'?
Job's a good 'un!
Because 1) accessing youtube is still using up our (very limited) bandwidth (in fact it adds an additional bottleneck in because all our branches route through our head office stack to get to the internet), and 2) that puts it outside our firewall and therefore we can't share any confidential information.
We do use youtube and vimeo for occasional things but in general we have to use an internal process to replicate files out overnight. Max file size of 80MB - even in B&W that looks pretty shoddy! :D
Postby CS70 » Tue Aug 06, 2019 4:35 pm
Ahh yeah! Mine was supposed to be below 50Gb, basically a GIF would have done better!! :D
Postby Mike Stranks » Thu Aug 08, 2019 10:01 am
Job's a good 'un!
Fair enough...
Been there, done that, got the T-shirt. My work experience of such matters is now 10 years out of date. I'd anticipated that the world might have moved on... obviously not.
Mike Stranks
Postby blinddrew » Thu Aug 08, 2019 11:28 am
Mike Stranks wrote:Been there, done that, got the T-shirt. My work experience of such matters is now 10 years out of date. I'd anticipated that the world might have moved on... obviously not.
A more than reasonable expectation. :)
In some matters we're very progressive, in some matters we're still 10 years behind where you were ten years ago! ;)
It was only in the last couple of years that we stopped having branches with dial-up connections... :o
Postby gsc1ugs » Thu Aug 15, 2019 3:06 pm
Ok everyone who's interested, i got all my files in wav 1411kbps and boy can you tell the difference, have a couple questions, i cant edit properties to change title track names, if i import into audacity then export which at this point i cant edit this, will i loose the quality again?
gsc1ugs
Postby The Elf » Thu Aug 15, 2019 4:19 pm
Postby gsc1ugs » Thu Aug 15, 2019 5:13 pm
Great no need to reprocess wavs
gsc1ugs
Postby ben howes » Fri Aug 16, 2019 1:05 pm
Codecs aside..
I'd recommend a dedicated player rather than a phone.
phone notification bleeps arriving over the PA is very naff. I've also experienced that syncopated rhythm of the cellular radio spilling out of the audio jack.
Aeroplane mode might help.
I also find the 3.5mm socket on many phones is not reliable from an electrical connection.
ben howes
Postby The Elf » Fri Aug 16, 2019 1:09 pm
ben howes wrote:I also find the 3.5mm socket on many phones is not reliable from an electrical connection.
If you even get one. Apple?!?!?!? :protest: :x :protest: :x
PreviousNext
