Quick mp3 question
Re: Quick mp3 question
Postby gsc1ugs » Sat Aug 03, 2019 6:57 pm
:headbang: :headbang: :headbang: :headbang: :headbang: :headbang: :headbang: :headbang:
I dont have the masters they are sold as mp3 even paris music
gsc1ugs
Postby Hugh Robjohns » Sun Aug 04, 2019 12:54 am
hobbyist wrote:I thought I saw results from AES many many years ago on topics like this, doing ABCX double blind tests.
There have been lots of proper double blind testing of mp3 and many other lossy codecs over the years, reported in depth by pretty much all the standards bodies. The audibility of coding artefacts is almost entirely dependent on the coding bit-rate. Most people would probably agree that low bit-rate mp3s sound terrible. Equally, most people would find it difficult to distinguish between high bit-rate mp3 and an original source wav...
I recall they saying that some folks could identify when they used 192 and 384 rates and said they sounded better. That was A/D/A not mp3 specifically though.
Maybe I'm misunderstanding here, but you appear to be confusing converter sample rates with lossy-codec bit rates... .
Storage is cheap now. There is no need to compress to save memory or disk space like the old days.
Perhaps not... And broadband rates are generally much higher too so it's less necessary for streaming services too... But it will be a long time before lossy codecs genuinely become unnecessary and obsolete.
Postby Hugh Robjohns » Sun Aug 04, 2019 1:05 am
Don't get me wrong -- it's not the end of the world using mp3s as backing tracks. Artists are doing it all over the world all the time and they probably receive very few complaints. If that's all you have to use, then use them.
But as a general policy it will sound better if you avoid mp3 files where you can. Pick Wavs or Aiffs, or less-less data-reduced formats like Flac or Alac.
If you have to use mp3s (or other lossy codec formats), then use the highest bit-rates you can get -- certainly above 192kbps, and ideally 320kbps for mp3s.
Postby Eddy Deegan » Sun Aug 04, 2019 11:57 am
I did a bit of googling and found this: https://www.npr.org/sections/therecord/ ... io-quality
It's 6 extracts of various genres, with 3 versions of each: mp3 128kbps / mp3 320Kbps / uncompressed WAV, and you select which one you think is the best.
I didn't get all of them right. On four of them I picked the WAV and the other two I picked the 320kpbs mp3. That said I was listening via a bluetooth connection to my hifi, so that may have made a difference. Genre/busy-ness of the mix may also make a difference, also if you're listening to material you are familiar listening to on CD.
I'm going to retry it later on the DAW PC connected to my monitors and see how I find that.
Some of my musical works.
Postby gsc1ugs » Sun Aug 04, 2019 12:11 pm
2 right :thumbdown: not sure i would hear real quality on this stacker i have from 80's :lol: :lol:
gsc1ugs
Postby gsc1ugs » Sun Aug 04, 2019 12:12 pm
another massive factor to me is compressed audio, that coldplay one is awwwwwwefull
gsc1ugs
Postby Sam Spoons » Sun Aug 04, 2019 12:17 pm
Just a question, are you dissatisfied with the sound of your present .mp3 tracks? If they are commercial tracks they will most likely be high bitrate mp3s and IME the artefacts present in high bitrate .mp3s will not be noticed by the majority of listeners (those of us who have learned to recognise them are, obviously, a different matter) and I doubt most of your audience would notice (I've never had anybody complain about the quality of .mp3 sourced break music on a gig).
gsc1ugs wrote:another massive factor to me is compressed audio, that coldplay one is awwwwwwefull
There's a fundamental difference between audio compression (as in that Coldplay track) and data compression (as in .mp3s).
Postby gsc1ugs » Sun Aug 04, 2019 12:42 pm
Most are very good, i do have some under 128 but original question was about digital playback, i use my daily iPhone for my gigs its great just wanted clear up that playback argument but seem to have opened a can of worms. My provider is kindly sending me wav versions to eliminate that problem for small fee
gsc1ugs
Postby The Elf » Sun Aug 04, 2019 12:47 pm
gsc1ugs wrote::headbang: :headbang: :headbang: :headbang: :headbang: :headbang: :headbang: :headbang:
A perennial problem when I'm working with artists who bring me backing tracks. Why backing providers seem reluctant to offer lossless audio is silly and annoying!
And, to echo others here... DON'T convert MP3 to WAV!!! Not only is it pointless, but should it be converted back again the quality goes down the toilet.
Postby blinddrew » Sun Aug 04, 2019 4:35 pm
gsc1ugs wrote:My provider is kindly sending me wav versions to eliminate that problem for small fee
Sounds like the best solution. :thumbup:
Postby gsc1ugs » Sun Aug 04, 2019 5:44 pm
Cheers folks
gsc1ugs
Postby Martin Walker » Sun Aug 04, 2019 7:41 pm
if anyone is till interested in exploring the mid-side stuff in more detail, I've tracked down an old izotope blog from 2014 that first got me excited about the possibilities:
https://www.izotope.com/en/blog/mixing/ ... nking.html
Here's an idea of what's on offer:
"Listening In Side
I started thinking about this some years ago after I had the good fortune to serve as host for mastering engineer Bob Ludwig when he came to talk to my students at SUNY/Fredonia. In the course of some fairly extended conversation, he told me that he always listened to the Side version of recordings that he mastered and that he'd come to find them very interesting from a production standpoint as well as a technical one. He found various producers' characteristic practices and tricks were much more audible in Side, and that many elements of the original tracks were more clearly revealed in Side. He suggested that my students might find it useful to listen to recordings this way in order to quickly identify and comprehend various producers' styles."
And of course there's plenty on offer from the SOS archives too:
https://www.soundonsound.com/techniques ... processing
Postby AlecSp » Sun Aug 04, 2019 9:27 pm
Late to the party on this one, but mp3 bitrates:
In my original ripping experience I was naive on the bitrate and didn't discover until later that I'd been using a default rate of 128kbps. Nothing emerged on the cheap PC earphones I was using with that. My shock came when I used a 128kbps copy of Bohemian Rhapsody at a funeral on a church's cheap PA - it was embarassing. Genuinely that bad.
This prompted some comparative listening, and 128 vs 256 kbps mp3s were night & day different. But I quickly moved to 320kbps as the storage increase was minimal. In all practical situations I am happy that the quality of a 320kbps mp3 is not the limitation in the signal chains that I use.
Sadly, despite what some people would like to think, we're in a world of MP3 for music consumption. Lossless formats may be "better", but they're not as universally usable. So, for me, utility outweighs the last smidgin of notional technical performance and tips the balance back in favour of (decently encoded) MP3
Don't forget that what you're listening to can never really sound better than the worst part of the signal chain.
AlecSp
Postby hobbyist » Mon Aug 05, 2019 1:02 am
I can tell the difference between mp3s and wav even though I am not one of the golden eared folks.
Not confusing. The article I read was about converters. I just extrapolated to saying AES must have done similar tests for various bit rates on codecs as well as other comparisons.
As far as I am concerned, lossy codecs are obsolete now. I agree that they will be around for a long time anyway.
hobbyist
Postby CS70 » Mon Aug 05, 2019 12:16 pm
Eddy Deegan wrote:I was listening via a bluetooth connection to my hifi
For the MP3s, yeah you may or may not have another layer of encoding on top - it depends on the bluetooth devices. The standard common-denominator LCSC encoder is indeed awful for music due to the narrow bandwidth, but a bluetooth source/receiver couple can support MP3 streaming directly if both source and receiver ("sink") agree to it.
For the WAV however, it will definitely be subject to lossy compression, so you're not listening to the actual PCM data over bluetooth. So what you were comparing were, at best, two different lossy codecs (and at worst, two equally bad LCSC-encoded audio streams)
The best is to simply access the sound file as a data storage (so it's sent verbatim) and play it over the monitors via an audio interface. Or, if you want to go hifi, either go cabled or burn a cd :)
Postby Hugh Robjohns » Mon Aug 05, 2019 12:50 pm
hobbyist wrote:As far as I am concerned, lossy codecs are obsolete now. I agree that they will be around for a long time anyway.
Just for clarity, obsolete means 'no longer produced or used' but, sadly, neither is the case for lossy-codecs in general, or MP3 specifically.
I agree with your (earlier) point that in many cases it is now perfectly practical to use raw linear PCM tracks, or encode with loss-less codecs -- because mass data storage is so cheap, and data bandwidth is now very high in many situations (cable/fibre broadband, 4G/5G mobile broadband etc).
So, like you, I would definitely urge people to use either raw linear PCM or loss-less codecs (FLAC, ALAC etc) whenever they possibly can.
Personally, I like to use ALAC because it is a bit-accurate loss-less encoder that saves around 50% of the raw files space, but it has all the convenient standardised metadata capabilities of MP3, which I find extremely useful. Flac is much less well organised in this respect...
However, the fact is that lossy codecs are very far from being 'obsolete', and it would be very ill-advised indeed to think they are.
Lossy codecs are employed in all the current Satellite and DTT TV broadcasting services, and in digital radio, for example. They are employed in the soundtracks of DVDs and many Blu-ray discs. They are also employed in all the streaming TV media services (Netflix, Amazon Prime etc, Youtube), as well as in music feeds like Spotify, Deezer etc.
As you say, none of these will be going away in the foreseeable future, and while some services do now offer a loss-less codec option (eg, Deezer Hi-fi) for a higher monthly fee the take up is not exactly huge...
So I'd say that while lossy-codecs are avoidable in many situations, they are far from obsolete.
Postby gsc1ugs » Mon Aug 05, 2019 1:42 pm
In a nutshell Image
gsc1ugs
Postby gsc1ugs » Mon Aug 05, 2019 1:43 pm
My wav files are in the post even if my ears cant hear 128bit v wav :beamup:
gsc1ugs
Postby Kwackman » Mon Aug 05, 2019 2:08 pm
gsc1ugs wrote:In a nutshell Image
Nope.
The sample rate (should be 44.1 kHz) and word length can be different in either format.
A WAV file can be (and on audio CDs are) 44.1kHz, 16bit.
There may be other good articles in the SOS archive, but I found these.
Get a large cup of coffee. ;)
https://www.soundonsound.com/sound-advi ... udio-files
https://www.soundonsound.com/techniques ... your-music
Kwackman
Postby CS70 » Mon Aug 05, 2019 2:35 pm
AlecSp wrote:Sadly, despite what some people would like to think, we're in a world of MP3 for music consumption. Lossless formats may be "better", but they're not as universally usable. So, for me, utility outweighs the last smidgin of notional technical performance and tips the balance back in favour of (decently encoded) MP3
The difficulty with these things is that it's easy to overgeneralize - the devil is often in the the details (i.e. the context of usage).
Lossy codecs don't just cut away random pieces of sound - the original work at Fraunhofer was the pinnacle of two decades of research by people who knew what they were doing and build up on existing science (general error-correcting coding for example) and invented some new to do achieve the compression - psychoacoustic coding and perceptual entropy, for example.
Sure, the science is based on certain assumptions but these assumptions (and the corresponding algorithms) have been tested, verified and adapted several times over years before the format was finalized. In comparison with the similar work at JPEG, most of the pictures we see on the webs or even in magazines are compressed and nobody is the wiser. Try to print a mega-poster from them tough, and you'll see odd stuff if you go near.. but a megaposter is supposed to be seen from afar, so even in that case JPEG is effective.
For a phone jingle, even a very low bitrate lossy codec work just fine. A 128Kpbs MP3 is not necessarily bad: the Germans' theory was that it could actually represent quite well a CD quality signal while compressing size down to an average of 12 times. Constant bitrate is simply sample rate for the bit depth, so16bit, 44.1Khz sampling rate, which for two channels means 1411.2kbps - going down to 128Kbps means 11 times lower, with the final step being normal Huffman compression. Every step effectiveness depends also on the material - even the simple data encoding really depends on how many sequences of bit repeat in the data stream, and for how long.
Here's how it works In brief (and cutting a lot of detail), for each frame (1152 samples), there's 32 sub-bands - in line with the way that most people can hear differences in the various frequencies. The actual width depends on the sampling rate, and each samples is chuncked down to the bands (i.e. multiple samples, containing their specific part of the spectrum, are created from one). Since it's filtering, some aliasing will be introduced. Then 31 of the 32 samples are discarded, i.e. only a specific frequency are is represented in that sample - all the other bits are zero. Then "windowing" is applied - to average the signal and basically reduce the impact of the sample boundaries - and it's a critical step, as the algorithm looks at how similar consecutive samples are and - if they are similar - uses a "long" window, if they are not, a "short" one: a long window effectively says "the signal stays the same", and does reduce a certain amount of detail. The trick is in the definition of "similar". The psychoacoustic model is applied during windowing to provide information for that - leading, if necessary, to discard parts which are unadible according to an assumed model of human hearing - it tells the algorithm when to use short windows or long windows. The result is further processed to scale the data so that noise remains below what the PA model say is imperceptible, and the the optimal quantization step size for Huffman encoding (to find the "words" which are meaningful to look at). Finally, the resulting samples sequences is Huffman-encoded (in other words, zipped :) ).
So the algorithm depends on how finely the average ear can distinguish bands, and the PA model determine what is considered discardable, what is perceived as "the same sound" for each band and what noise is considered imperceptible. And that's why certain people can hear stuff and other don't.
Also, the standard leaves quite a bit open to the implementation, so it really makes no sense to talk of "Mp3 encoding at XX bitrate" by itself. What encoder is used is important! For example, what do we do with freqs over 16KHz? Some encoders may discard them entirely - and a young person with good ears may notice it; some encoder won't and even develop their own models to deal with these freqs. For example Lame mp3 is a very good open source encoder - perhaps the best.. we can't know as others are closed-source.
Not to mention variable bitrate encoding, where other models are used to decided when to keep the bitrate low or increase it temporarily, by preprocessing and analyzing the data stream!
So the science has (as always) limits: it can tell what the averages are, but by definition different data streams may yield different result, and a large amount of empirical data is needed to get some statistical conclusion. After many years of adoption, it seems that with a good encoder, a 256/320kps bitrate is definitely good enough, and 128kps holds water in many cases for most people, as theorized. No surprise most people don't complain!
Exactly like any other tool, if time and cost permit, it's always best to use the best available - so, in days far removed from 1992 (i.e. abundant, cheap fast storage), lossless files are certainly the way to go. But as Hugh noticed, in limited bandwidth situation (as over a cellular network for example) the compressing power of MP3 can still be of great use.
