QSC TouchMix screen issue
Postby Dave B » Fri Sep 20, 2019 1:23 pm
I think we’ve mentioned this before, but I have just had a bit of a worrying thing happen on my TM16. All booted up fine, but the second the screen was touched, it went off. I had this once before, and a reboot cleared it. This time, we power cycled it a few times and it didn’t clear - unit worked fine, so we ran it from an iPad. After rehearsal, we cycled one more time and it was fine. Odd.
(Emergency backup Berry XR18should arrive tomorrow in case this becomes a real issue)
Advice needed : do I try to get it serviced/repaired? There is an authorised service centre relatively close by, and it’s not the cost that I worry about, it’s the intermittent nature of the issue. Do I hold off and see if it recurs? Or pull the trigger quickly?
Thoughts?
Dave B
Re: QSC TouchMix screen issue
Postby Mike Stranks » Fri Sep 20, 2019 3:11 pm
Have you talked to QSC about it?
Couldn't possibly be iffy mains could it?
Mike Stranks
